Ran several cuts today and things were going great. Then I noticed as the machine was cutting that the bottom right belt seemed a bit loose. Sure enough it seemed to feed too much and chewed up my belt. What do I need to look for?
Serial Messages
Index.html Version: 0.82
[MSG:INFO: FluidNC v0.81 (Maslow-Main-b6772b63-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Coopers]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 10.0.0.30]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:ERR: Please press Retract All before using Extend All]
[MSG:INFO: Bottom Right pulled tight with offset 163.575]
[MSG:INFO: Top Left pulled tight with offset -1184.985]
[MSG:INFO: Bottom Left pulled tight with offset -1769.425]
[MSG:INFO: Top Right pulled tight with offset -2595.824]
[MSG:INFO: Top Right pulled tight with offset -0.043]
[MSG:INFO: Top Left pulled tight with offset -0.032]
[MSG:INFO: Bottom Left pulled tight with offset -0.021]
[MSG:INFO: Bottom Right pulled tight with offset -3106.561]
[MSG:INFO: Top Left pulled tight with offset -0.021]
[MSG:INFO: Bottom Right pulled tight with offset -0.075]
[MSG:INFO: Top Right pulled tight with offset -0.032]
Jog: Z5
Jog: Z5
Jog: Z-1
Jog: Z-1
Jog: Z-1
Jog: Z-1
Jog: Z0.25
Home pos set for: Z
[G54:0.000,0.000,121.330]
Jog: Z5
[MSG:INFO: Center point deviation: TL: -0.000 TR: 0.128 BL: 3.142 BR: 2.288]
[MSG:INFO: Center point deviation within 15.000mm, your coordinate system is accurate]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.007mm Counter: 1]
[MSG:WARN: Previous error was 15.007mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.007mm Counter: 2]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.016mm Counter: 3]
[MSG:WARN: Previous error was 15.016mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.024mm Counter: 4]
[MSG:WARN: Previous error was 15.024mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.032mm Counter: 5]
[MSG:WARN: Previous error was 15.032mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.032mm Counter: 6]
[MSG:INFO: Reset during file job at line: 220]
[MSG:ERR: Position error > 15mm while running. E-Stop triggered.]
Have you installed the latest belt guide 3d printed parts? I have heard these are not perfect but they should reduce the chances of happening again I think. They also sell the replacement belts and spools, which you will probably need.
I have not. I was able to get it running again and did a recalibration. It ran 2 cuts perfectly. I then go to make a 3rd cut and about halfway through it just took off. I tried to cut it again just to test (as the piece was already ruined) and about 3/4 way through it took off again. Very frustrating.
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
[MSG:INFO: Set to comply]
[MSG:INFO: Bottom Right pulled tight with offset -2.169]
[MSG:INFO: Top Right pulled tight with offset -1296.103]
[MSG:INFO: Top Left pulled tight with offset -2553.835]
[MSG:INFO: Bottom Left pulled tight with offset -2811.168]
[MSG:INFO: Top Right pulled tight with offset 0.118]
[MSG:INFO: Top Left pulled tight with offset 0.011]
[MSG:INFO: Bottom Left pulled tight with offset -0.032]
[MSG:INFO: Bottom Right pulled tight with offset -1719.352]
[MSG:INFO: Bottom Right pulled tight with offset -0.054]
[MSG:INFO: Top Right pulled tight with offset -0.086]
[MSG:INFO: Top Left pulled tight with offset -0.097]
[MSG:INFO: Bottom Left pulled tight with offset -0.097]
Jog: Z-5
Jog: Z-5
Jog: Z-5
Jog: Z-5
Jog: Z-5
Jog: Z-5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z-5
Jog: Z-1
Jog: Z-1
Jog: Z-1
Jog: Z-0.5
Home pos set for: Z
[G54:0.000,0.000,31.500]
Jog: Z1
Jog: Z1
Jog: Z1
Jog: Z1
[MSG:INFO: Center point deviation: TL: 0.002 TR: 0.475 BL: -10.591 BR: 0.195]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -15.646mm Counter: 1]
[MSG:WARN: Previous error was -15.646mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -15.646mm Counter: 2]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -15.654mm Counter: 3]
[MSG:WARN: Previous error was -15.654mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -15.654mm Counter: 4]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -15.662mm Counter: 5]
[MSG:WARN: Previous error was -15.662mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -16.026mm Counter: 1]
[MSG:WARN: Previous error was -16.026mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -16.034mm Counter: 2]
[MSG:WARN: Previous error was -16.034mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -16.034mm Counter: 3]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -16.052mm Counter: 4]
[MSG:WARN: Previous error was -16.052mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -16.060mm Counter: 5]
[MSG:WARN: Previous error was -16.060mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 26.866mm Counter: 1]
[MSG:WARN: Previous error was 26.866mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 26.866mm Counter: 2]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 26.858mm Counter: 3]
[MSG:WARN: Previous error was 26.858mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 26.849mm Counter: 4]
[MSG:WARN: Previous error was 26.849mm]
Now as I try again to extend all belts, the fan quit working and bottom right encoder failed to read. The error is scrolling on my screen. What am I doing wrong?
Annnndd…now when I reset everything, it fails to retract all. No response…it’s too early on a Friday to quit now!
@bar @dlang sorry to tag you but I am at a loss. I’ve done the hot glue fix to no avail. I keep getting errors and issues during cutting. I’ve recalibrated several times. Could I have a bad board?
I encountered this encoder failure first. I then reset everything to center and tried again only to get this position error. What gives???
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
[MSG:INFO: Bottom Right pulled tight with offset -2056.873]
[MSG:INFO: Top Right pulled tight with offset -2038.782]
[MSG:INFO: Top Left pulled tight with offset -2043.173]
[MSG:INFO: Bottom Left pulled tight with offset -2062.595]
[MSG:INFO: Center point deviation: TL: 0.064 TR: 0.059 BL: -2.351 BR: -5.933]
[MSG:INFO: Center point deviation: TL: 0.005 TR: -0.011 BL: -1.436 BR: -5.321]
CLBM:[{bl:2202.52, br:2191.33, tr:2193.43, tl:2197.59},{bl:2137.30, br:2129.79, tr:2261.29, tl:2262.37},{bl:1927.08, br:2341.37, tr:2467.18, tl:2074.00},{bl:1999.11, br:2402.60, tr:2405.42, tl:1995.13},{bl:2076.14, br:2468.48, tr:2344.84, tl:1921.08},{bl:2271.95, br:2268.63, tr:2126.86, tl:2125.54},{bl:2478.52, br:2072.98, tr:1916.65, tl:2342.47},{bl:2415.97, br:1994.06, tr:1987.65, tl:2402.22},{bl:2355.26, br:1920.06, tr:2065.53, tl:2468.56},]
Computing… This may take several minutesFitness: 1.8848393 in 100
Fitness: 1.8848393 in 200
Fitness: 1.8848393 in 300
Fitness: 1.8848393 in 400
Fitness: 1.8848393 in 500
Fitness: 1.8848393 in 600
Fitness: 1.8848393 in 700
Fitness: 1.8848393 in 800
Fitness: 1.8848393 in 900
Fitness: 1.8848393 in 1000
Calibration complete
Calibration values:
Fitness: 1.8848393325256168
Maslow_tlX: 10.2
Maslow_tlY: 2443.5
Maslow_trX: 3657.1
Maslow_trY: 2437.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3655.4
Maslow_brY: 0.0
A command to save these values has been successfully sent for you. Please check for any error messages.
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
CLBM:[{bl:2202.52, br:2191.33, tr:2193.43, tl:2197.59},{bl:2137.30, br:2129.79, tr:2261.29, tl:2262.37},{bl:1927.08, br:2341.37, tr:2467.18, tl:2074.00},{bl:1999.11, br:2402.60, tr:2405.42, tl:1995.13},{bl:2076.14, br:2468.48, tr:2344.84, tl:1921.08},{bl:2271.95, br:2268.63, tr:2126.86, tl:2125.54},{bl:2478.52, br:2072.98, tr:1916.65, tl:2342.47},{bl:2415.97, br:1994.06, tr:1987.65, tl:2402.22},{bl:2355.26, br:1920.06, tr:2065.53, tl:2468.56},{bl:2299.68, br:1849.35, tr:2150.59, tl:2539.62},{bl:2075.89, br:2064.41, tr:2337.60, tl:2345.73},{bl:1858.81, br:2288.29, tr:2536.86, tl:2157.08},{bl:1650.87, br:2514.58, tr:2744.42, tl:1982.10},{bl:1727.69, br:2565.12, tr:2682.75, tl:1891.20},{bl:1811.67, br:2620.25, tr:2622.54, tl:1804.30},{bl:1893.43, br:2680.30, tr:2567.06, tl:1722.19},{bl:1984.75, br:2745.13, tr:2516.56, tl:1645.43},{bl:2160.08, br:2542.19, tr:2287.79, tl:1852.85},{bl:2348.31, br:2342.97, tr:2064.00, tl:2066.62},{bl:2547.73, br:2154.36, tr:1846.90, tl:2290.55},{bl:2757.84, br:1979.45, tr:1639.12, tl:2518.95},{bl:2694.89, br:1888.42, tr:1717.35, tl:2567.60},{bl:2634.65, br:1801.40, tr:1799.43, tl:2622.23},{bl:2579.05, br:1719.13, tr:1885.70, tl:2682.93},{bl:2528.44, br:1642.15, tr:1977.81, tl:2748.71},]
Computing… This may take several minutesFitness: 0.9069918 in 100
Fitness: 0.9069918 in 200
Fitness: 0.9069918 in 300
Fitness: 0.9069918 in 400
Fitness: 0.9069918 in 500
Fitness: 0.9069918 in 600
Fitness: 0.9069918 in 700
Fitness: 0.9069918 in 800
Fitness: 0.9069918 in 900
Fitness: 0.9069918 in 1000
Calibration values:
Fitness: 0.9069918002499308
Maslow_tlX: 10.2
Maslow_tlY: 2443.5
Maslow_trX: 3657.1
Maslow_trY: 2437.6
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3656.0
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Measured waypoint 48]
CLBM:[{bl:2202.52, br:2191.33, tr:2193.43, tl:2197.59},{bl:2137.30, br:2129.79, tr:2261.29, tl:2262.37},{bl:1927.08, br:2341.37, tr:2467.18, tl:2074.00},{bl:1999.11, br:2402.60, tr:2405.42, tl:1995.13},{bl:2076.14, br:2468.48, tr:2344.84, tl:1921.08},{bl:2271.95, br:2268.63, tr:2126.86, tl:2125.54},{bl:2478.52, br:2072.98, tr:1916.65, tl:2342.47},{bl:2415.97, br:1994.06, tr:1987.65, tl:2402.22},{bl:2355.26, br:1920.06, tr:2065.53, tl:2468.56},{bl:2299.68, br:1849.35, tr:2150.59, tl:2539.62},{bl:2075.89, br:2064.41, tr:2337.60, tl:2345.73},{bl:1858.81, br:2288.29, tr:2536.86, tl:2157.08},{bl:1650.87, br:2514.58, tr:2744.42, tl:1982.10},{bl:1727.69, br:2565.12, tr:2682.75, tl:1891.20},{bl:1811.67, br:2620.25, tr:2622.54, tl:1804.30},{bl:1893.43, br:2680.30, tr:2567.06, tl:1722.19},{bl:1984.75, br:2745.13, tr:2516.56, tl:1645.43},{bl:2160.08, br:2542.19, tr:2287.79, tl:1852.85},{bl:2348.31, br:2342.97, tr:2064.00, tl:2066.62},{bl:2547.73, br:2154.36, tr:1846.90, tl:2290.55},{bl:2757.84, br:1979.45, tr:1639.12, tl:2518.95},{bl:2694.89, br:1888.42, tr:1717.35, tl:2567.60},{bl:2634.65, br:1801.40, tr:1799.43, tl:2622.23},{bl:2579.05, br:1719.13, tr:1885.70, tl:2682.93},{bl:2528.44, br:1642.15, tr:1977.81, tl:2748.71},{bl:2483.10, br:1572.04, tr:2069.65, tl:2814.84},{bl:2249.90, br:1785.34, tr:2234.21, tl:2619.23},{bl:2020.42, br:2009.33, tr:2417.22, tl:2426.08},{bl:1796.50, br:2238.48, tr:2611.67, tl:2244.21},{bl:1580.56, br:2469.84, tr:2812.81, tl:2076.55},{bl:1376.07, br:2706.07, tr:3022.99, tl:1926.87},{bl:1456.46, br:2746.62, tr:2961.86, tl:1824.65},{bl:1542.45, br:2791.96, tr:2902.04, tl:1725.44},{bl:1632.90, br:2844.22, tr:2846.43, tl:1629.73},{bl:1729.49, br:2898.39, tr:2795.34, tl:1538.35},{bl:1827.66, br:2958.59, tr:2748.97, tl:1451.93},{bl:1929.09, br:3023.36, tr:2707.58, tl:1371.35},{bl:2078.16, br:2819.09, tr:2471.37, tl:1572.85},{bl:2247.73, br:2617.01, tr:2237.93, tl:1788.34},{bl:2430.48, br:2423.88, tr:2008.61, tl:2011.48},{bl:2623.73, br:2242.02, tr:1784.75, tl:2240.99},{bl:2824.80, br:2074.42, tr:1568.90, tl:2473.88},{bl:3033.17, br:1924.83, tr:1364.70, tl:2707.48},{bl:2973.93, br:1822.46, tr:1447.34, tl:2747.68},{bl:2914.11, br:1723.17, tr:1533.67, tl:2793.70},{bl:2858.47, br:1627.28, tr:1623.69, tl:2845.30},{bl:2807.33, br:1535.74, tr:1719.55, tl:2900.85},{bl:2760.91, br:1449.08, tr:1818.06, tl:2963.33},{bl:2719.43, br:1368.53, tr:1920.09, tl:3023.59},]
Computing… This may take several minutesFitness: 0.7440449 in 100
Fitness: 0.7440449 in 200
Fitness: 0.7440449 in 300
Fitness: 0.7440449 in 400
Fitness: 0.7440449 in 500
Fitness: 0.7440449 in 600
Fitness: 0.7440449 in 700
Fitness: 0.7440449 in 800
Fitness: 0.7440449 in 900
Fitness: 0.7440449 in 1000
Calibration values:
Fitness: 0.7440449063838979
Maslow_tlX: 10.5
Maslow_tlY: 2440.6
Maslow_trX: 3657.3
Maslow_trY: 2438.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3658.5
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 49]
[MSG:INFO: Measured waypoint 50]
[MSG:INFO: Measured waypoint 51]
[MSG:INFO: Measured waypoint 52]
[MSG:INFO: Measured waypoint 53]
[MSG:INFO: Measured waypoint 54]
[MSG:INFO: Measured waypoint 55]
[MSG:INFO: Measured waypoint 56]
[MSG:INFO: Measured waypoint 57]
[MSG:INFO: Measured waypoint 58]
[MSG:INFO: Measured waypoint 59]
[MSG:INFO: Measured waypoint 60]
[MSG:INFO: Measured waypoint 61]
[MSG:INFO: Measured waypoint 62]
[MSG:INFO: Measured waypoint 63]
[MSG:INFO: Measured waypoint 64]
[MSG:INFO: Measured waypoint 65]
[MSG:INFO: Measured waypoint 66]
[MSG:INFO: Measured waypoint 67]
[MSG:INFO: Measured waypoint 68]
[MSG:INFO: Measured waypoint 69]
[MSG:INFO: Measured waypoint 70]
[MSG:INFO: Measured waypoint 71]
[MSG:INFO: Measured waypoint 72]
[MSG:INFO: Measured waypoint 73]
[MSG:INFO: Measured waypoint 74]
[MSG:INFO: Measured waypoint 75]
[MSG:INFO: Measured waypoint 76]
[MSG:INFO: Measured waypoint 77]
[MSG:INFO: Measured waypoint 78]
[MSG:INFO: Measured waypoint 79]
[MSG:INFO: Measured waypoint 80]
CLBM:[{bl:2202.52, br:2191.33, tr:2193.43, tl:2197.59},{bl:2137.30, br:2129.79, tr:2261.29, tl:2262.37},{bl:1927.08, br:2341.37, tr:2467.18, tl:2074.00},{bl:1999.11, br:2402.60, tr:2405.42, tl:1995.13},{bl:2076.14, br:2468.48, tr:2344.84, tl:1921.08},{bl:2271.95, br:2268.63, tr:2126.86, tl:2125.54},{bl:2478.52, br:2072.98, tr:1916.65, tl:2342.47},{bl:2415.97, br:1994.06, tr:1987.65, tl:2402.22},{bl:2355.26, br:1920.06, tr:2065.53, tl:2468.56},{bl:2299.68, br:1849.35, tr:2150.59, tl:2539.62},{bl:2075.89, br:2064.41, tr:2337.60, tl:2345.73},{bl:1858.81, br:2288.29, tr:2536.86, tl:2157.08},{bl:1650.87, br:2514.58, tr:2744.42, tl:1982.10},{bl:1727.69, br:2565.12, tr:2682.75, tl:1891.20},{bl:1811.67, br:2620.25, tr:2622.54, tl:1804.30},{bl:1893.43, br:2680.30, tr:2567.06, tl:1722.19},{bl:1984.75, br:2745.13, tr:2516.56, tl:1645.43},{bl:2160.08, br:2542.19, tr:2287.79, tl:1852.85},{bl:2348.31, br:2342.97, tr:2064.00, tl:2066.62},{bl:2547.73, br:2154.36, tr:1846.90, tl:2290.55},{bl:2757.84, br:1979.45, tr:1639.12, tl:2518.95},{bl:2694.89, br:1888.42, tr:1717.35, tl:2567.60},{bl:2634.65, br:1801.40, tr:1799.43, tl:2622.23},{bl:2579.05, br:1719.13, tr:1885.70, tl:2682.93},{bl:2528.44, br:1642.15, tr:1977.81, tl:2748.71},{bl:2483.10, br:1572.04, tr:2069.65, tl:2814.84},{bl:2249.90, br:1785.34, tr:2234.21, tl:2619.23},{bl:2020.42, br:2009.33, tr:2417.22, tl:2426.08},{bl:1796.50, br:2238.48, tr:2611.67, tl:2244.21},{bl:1580.56, br:2469.84, tr:2812.81, tl:2076.55},{bl:1376.07, br:2706.07, tr:3022.99, tl:1926.87},{bl:1456.46, br:2746.62, tr:2961.86, tl:1824.65},{bl:1542.45, br:2791.96, tr:2902.04, tl:1725.44},{bl:1632.90, br:2844.22, tr:2846.43, tl:1629.73},{bl:1729.49, br:2898.39, tr:2795.34, tl:1538.35},{bl:1827.66, br:2958.59, tr:2748.97, tl:1451.93},{bl:1929.09, br:3023.36, tr:2707.58, tl:1371.35},{bl:2078.16, br:2819.09, tr:2471.37, tl:1572.85},{bl:2247.73, br:2617.01, tr:2237.93, tl:1788.34},{bl:2430.48, br:2423.88, tr:2008.61, tl:2011.48},{bl:2623.73, br:2242.02, tr:1784.75, tl:2240.99},{bl:2824.80, br:2074.42, tr:1568.90, tl:2473.88},{bl:3033.17, br:1924.83, tr:1364.70, tl:2707.48},{bl:2973.93, br:1822.46, tr:1447.34, tl:2747.68},{bl:2914.11, br:1723.17, tr:1533.67, tl:2793.70},{bl:2858.47, br:1627.28, tr:1623.69, tl:2845.30},{bl:2807.33, br:1535.74, tr:1719.55, tl:2900.85},{bl:2760.91, br:1449.08, tr:1818.06, tl:2963.33},{bl:2719.43, br:1368.53, tr:1920.09, tl:3023.59},{bl:2683.13, br:1296.89, tr:2020.36, tl:3092.20},{bl:2443.38, br:1510.74, tr:2162.84, tl:2891.91},{bl:2205.85, br:1733.26, tr:2322.92, tl:2695.16},{bl:1971.37, br:1962.01, tr:2498.47, tl:2507.91},{bl:1741.16, br:2197.42, tr:2687.30, tl:2332.44},{bl:1517.24, br:2432.87, tr:2885.79, tl:2171.64},{bl:1302.95, br:2670.42, tr:3090.14, tl:2029.05},{bl:1103.76, br:2910.30, tr:3299.99, tl:1908.74},{bl:1190.32, br:2943.19, tr:3241.46, tl:1796.98},{bl:1283.19, br:2981.85, tr:3181.96, tl:1687.04},{bl:1379.72, br:3024.96, tr:3126.31, tl:1579.37},{bl:1481.23, br:3069.96, tr:3074.74, tl:1474.59},{bl:1585.25, br:3123.19, tr:3027.48, tl:1373.08},{bl:1695.18, br:3179.04, tr:2984.67, tl:1275.62},{bl:1803.35, br:3238.83, tr:2946.57, tl:1183.55},{bl:1918.37, br:3302.50, tr:2913.33, tl:1097.96},{bl:2031.53, br:3098.13, tr:2671.94, tl:1294.58},{bl:2172.71, br:2893.73, tr:2432.17, tl:1510.24},{bl:2337.74, br:2697.01, tr:2194.50, tl:1732.11},{bl:2511.96, br:2509.79, tr:1960.08, tl:1962.18},{bl:2701.12, br:2334.38, tr:1729.86, tl:2196.65},{bl:2895.81, br:2173.66, tr:1506.21, tl:2431.65},{bl:3101.24, br:2031.01, tr:1292.03, tl:2670.13},{bl:3310.29, br:1910.61, tr:1093.24, tl:2910.30},{bl:3253.04, br:1798.81, tr:1181.27, tl:2939.82},{bl:3193.55, br:1688.83, tr:1272.82, tl:2979.43},{bl:3137.93, br:1581.11, tr:1369.77, tl:3021.19},{bl:3086.32, br:1476.21, tr:1470.35, tl:3068.05},{bl:3039.02, br:1374.50, tr:1575.25, tl:3119.30},{bl:2996.17, br:1276.96, tr:1681.97, tl:3178.06},{bl:2958.01, br:1184.60, tr:1793.12, tl:3237.99},{bl:2924.67, br:1098.69, tr:1903.92, tl:3301.16},]
Computing… This may take several minutesFitness: 0.5513519 in 100
Fitness: 0.5513519 in 200
Fitness: 0.5513519 in 300
Fitness: 0.5513519 in 400
Fitness: 0.5513519 in 500
Fitness: 0.5513519 in 600
Fitness: 0.5513519 in 700
Fitness: 0.5513519 in 800
Fitness: 0.5513519 in 900
Fitness: 0.5513519 in 1000
Calibration values:
Fitness: 0.5513518955505737
Maslow_tlX: 10.5
Maslow_tlY: 2440.6
Maslow_trX: 3657.6
Maslow_trY: 2438.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3658.6
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 81]
[MSG:INFO: Measured waypoint 82]
CLBM:[{bl:2202.52, br:2191.33, tr:2193.43, tl:2197.59},{bl:2137.30, br:2129.79, tr:2261.29, tl:2262.37},{bl:1927.08, br:2341.37, tr:2467.18, tl:2074.00},{bl:1999.11, br:2402.60, tr:2405.42, tl:1995.13},{bl:2076.14, br:2468.48, tr:2344.84, tl:1921.08},{bl:2271.95, br:2268.63, tr:2126.86, tl:2125.54},{bl:2478.52, br:2072.98, tr:1916.65, tl:2342.47},{bl:2415.97, br:1994.06, tr:1987.65, tl:2402.22},{bl:2355.26, br:1920.06, tr:2065.53, tl:2468.56},{bl:2299.68, br:1849.35, tr:2150.59, tl:2539.62},{bl:2075.89, br:2064.41, tr:2337.60, tl:2345.73},{bl:1858.81, br:2288.29, tr:2536.86, tl:2157.08},{bl:1650.87, br:2514.58, tr:2744.42, tl:1982.10},{bl:1727.69, br:2565.12, tr:2682.75, tl:1891.20},{bl:1811.67, br:2620.25, tr:2622.54, tl:1804.30},{bl:1893.43, br:2680.30, tr:2567.06, tl:1722.19},{bl:1984.75, br:2745.13, tr:2516.56, tl:1645.43},{bl:2160.08, br:2542.19, tr:2287.79, tl:1852.85},{bl:2348.31, br:2342.97, tr:2064.00, tl:2066.62},{bl:2547.73, br:2154.36, tr:1846.90, tl:2290.55},{bl:2757.84, br:1979.45, tr:1639.12, tl:2518.95},{bl:2694.89, br:1888.42, tr:1717.35, tl:2567.60},{bl:2634.65, br:1801.40, tr:1799.43, tl:2622.23},{bl:2579.05, br:1719.13, tr:1885.70, tl:2682.93},{bl:2528.44, br:1642.15, tr:1977.81, tl:2748.71},{bl:2483.10, br:1572.04, tr:2069.65, tl:2814.84},{bl:2249.90, br:1785.34, tr:2234.21, tl:2619.23},{bl:2020.42, br:2009.33, tr:2417.22, tl:2426.08},{bl:1796.50, br:2238.48, tr:2611.67, tl:2244.21},{bl:1580.56, br:2469.84, tr:2812.81, tl:2076.55},{bl:1376.07, br:2706.07, tr:3022.99, tl:1926.87},{bl:1456.46, br:2746.62, tr:2961.86, tl:1824.65},{bl:1542.45, br:2791.96, tr:2902.04, tl:1725.44},{bl:1632.90, br:2844.22, tr:2846.43, tl:1629.73},{bl:1729.49, br:2898.39, tr:2795.34, tl:1538.35},{bl:1827.66, br:2958.59, tr:2748.97, tl:1451.93},{bl:1929.09, br:3023.36, tr:2707.58, tl:1371.35},{bl:2078.16, br:2819.09, tr:2471.37, tl:1572.85},{bl:2247.73, br:2617.01, tr:2237.93, tl:1788.34},{bl:2430.48, br:2423.88, tr:2008.61, tl:2011.48},{bl:2623.73, br:2242.02, tr:1784.75, tl:2240.99},{bl:2824.80, br:2074.42, tr:1568.90, tl:2473.88},{bl:3033.17, br:1924.83, tr:1364.70, tl:2707.48},{bl:2973.93, br:1822.46, tr:1447.34, tl:2747.68},{bl:2914.11, br:1723.17, tr:1533.67, tl:2793.70},{bl:2858.47, br:1627.28, tr:1623.69, tl:2845.30},{bl:2807.33, br:1535.74, tr:1719.55, tl:2900.85},{bl:2760.91, br:1449.08, tr:1818.06, tl:2963.33},{bl:2719.43, br:1368.53, tr:1920.09, tl:3023.59},{bl:2683.13, br:1296.89, tr:2020.36, tl:3092.20},{bl:2443.38, br:1510.74, tr:2162.84, tl:2891.91},{bl:2205.85, br:1733.26, tr:2322.92, tl:2695.16},{bl:1971.37, br:1962.01, tr:2498.47, tl:2507.91},{bl:1741.16, br:2197.42, tr:2687.30, tl:2332.44},{bl:1517.24, br:2432.87, tr:2885.79, tl:2171.64},{bl:1302.95, br:2670.42, tr:3090.14, tl:2029.05},{bl:1103.76, br:2910.30, tr:3299.99, tl:1908.74},{bl:1190.32, br:2943.19, tr:3241.46, tl:1796.98},{bl:1283.19, br:2981.85, tr:3181.96, tl:1687.04},{bl:1379.72, br:3024.96, tr:3126.31, tl:1579.37},{bl:1481.23, br:3069.96, tr:3074.74, tl:1474.59},{bl:1585.25, br:3123.19, tr:3027.48, tl:1373.08},{bl:1695.18, br:3179.04, tr:2984.67, tl:1275.62},{bl:1803.35, br:3238.83, tr:2946.57, tl:1183.55},{bl:1918.37, br:3302.50, tr:2913.33, tl:1097.96},{bl:2031.53, br:3098.13, tr:2671.94, tl:1294.58},{bl:2172.71, br:2893.73, tr:2432.17, tl:1510.24},{bl:2337.74, br:2697.01, tr:2194.50, tl:1732.11},{bl:2511.96, br:2509.79, tr:1960.08, tl:1962.18},{bl:2701.12, br:2334.38, tr:1729.86, tl:2196.65},{bl:2895.81, br:2173.66, tr:1506.21, tl:2431.65},{bl:3101.24, br:2031.01, tr:1292.03, tl:2670.13},{bl:3310.29, br:1910.61, tr:1093.24, tl:2910.30},{bl:3253.04, br:1798.81, tr:1181.27, tl:2939.82},{bl:3193.55, br:1688.83, tr:1272.82, tl:2979.43},{bl:3137.93, br:1581.11, tr:1369.77, tl:3021.19},{bl:3086.32, br:1476.21, tr:1470.35, tl:3068.05},{bl:3039.02, br:1374.50, tr:1575.25, tl:3119.30},{bl:2996.17, br:1276.96, tr:1681.97, tl:3178.06},{bl:2958.01, br:1184.60, tr:1793.12, tl:3237.99},{bl:2924.67, br:1098.69, tr:1903.92, tl:3301.16},{bl:1971.35, br:1962.14, tr:2499.09, tl:2507.89},{bl:2201.99, br:2194.59, tr:2192.96, tl:2195.73},]
Computing… This may take several minutesFitness: 0.5487660 in 100
Fitness: 0.5487660 in 200
Fitness: 0.5487660 in 300
Fitness: 0.5487660 in 400
Fitness: 0.5487660 in 500
Fitness: 0.5487660 in 600
Fitness: 0.5487660 in 700
Fitness: 0.5487660 in 800
Fitness: 0.5487660 in 900
Fitness: 0.5487660 in 1000
Calibration values:
Fitness: 0.5487659789677756
Maslow_tlX: 10.5
Maslow_tlY: 2440.6
Maslow_trX: 3657.6
Maslow_trY: 2438.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3658.7
Maslow_brY: 0.0
[MSG:INFO: Calibration complete]
Home pos set for: Z
[G54:0.000,0.000,0.000]
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Y100
Jog: Y-100
Jog: Y-100
Jog: Z-5
Jog: Z-5
Jog: Z-5
Jog: Z-5
Jog: Z-5
Jog: Z1
Home pos set for: Z
[G54:0.000,0.000,41.000]
Jog: Z1
Jog: Z1
Jog: Z1
[MSG:WARN: Encoder read failure on Bottom Left]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 2 times in the last second]
[MSG:INFO: Reset during file job at line: 290]
[MSG:ERR: Emergency stop. Update function not being called enough.1001ms since last call]
Position error
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Z Axis driver test pass[MSG:INFO: Channel auto report interval set to 50 ms]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Z Axis driver test pass[MSG:INFO: Kinematic system: Cartesian]
[MSG:INFO: WiFi on]
Jog: Z5
error:8 - Command requires idle state. Unlock machine?
[MSG:INFO: Caution: Unlocked]
Jog: Z5
Jog: Z5
Jog: Z5
Jog: Z5
[MSG:INFO: Bottom Right pulled tight with offset -1837.706]
[MSG:INFO: Top Right pulled tight with offset -1943.199]
[MSG:INFO: Bottom Left pulled tight with offset -2165.726]
[MSG:INFO: Top Left pulled tight with offset -2254.245]
[MSG:INFO: Center point deviation: TL: 0.130 TR: 0.120 BL: 3.609 BR: 2.573]
Jog: Y-100
Jog: Y-100
Jog: Z-5
Jog: Z-5
Jog: Z-5
Home pos set for: Z
[G54:0.000,0.000,64.000]
Jog: Z5
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 1 times in the last second]
[MSG:INFO: Reset during file job at line: 300]
[MSG:ERR: Emergency stop. Update function not being called enough.1003ms since last call]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 14 times in the last second]
[MSG:ERR: Emergency stop. Update function not being called enough.1002ms since last call]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 40.898mm Counter: 1]
[MSG:WARN: Previous error was 40.898mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 40.898mm Counter: 2]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 40.914mm Counter: 3]
[MSG:WARN: Previous error was 40.914mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 40.914mm Counter: 4]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 40.920mm Counter: 5]
[MSG:WARN: Previous error was 40.920mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 40.856mm Counter: 6]
[MSG:WARN: Previous error was 40.856mm]
I’m getting totally lost jumping around from thread to thread
