I was wondering if anyone could share there bit settings for cutting with their Maslow.
What would you set for cutting 3/4" MDF or Melamine with a 1/4" router bit:
Feedrate?
Depth per pass?
Spindle speed on router?
Just like to get an idea where to start at. I think the MDF would be a little harder than the Melamine so if you have 2 different settings that’s nice to know too.
My advice is that it doesn’t actually matter that much. I’d go somewhere in the 1800 - 2000 mm/min range for the speed and start with 1/2 of the router bit diameter (so 1/8th inch depth of cut for a 1/4 inch router bit) and if that seems to work well I’d go up to the full router bit diameter for the depth of cut.
For cutting 3/4" MDF or Melamine with a 1/4" router bit on a Maslow CNC machine, the initial recommendations are as follows: For MDF, start with a feed rate of 60-80 IPM, a depth per pass of 1/8" to 1/4", and a spindle speed of 18,000-24,000 RPM; for Melamine, the feed rate and depth per pass are similar to MDF, with a spindle speed also in the range of 18,000-24,000 RPM. Please adjust these settings based on your specific conditions for optimal cutting results.
cutting results.
