Hello,
I’m going to buy a Maslow 4 when my garage will be completely built.
My plan is to use the CNC to create cabinets and furnitures with mainly plywood (18-22mm).
I’ve used the search function but I’ve only managed to find informations about the Maslow 1 (with chains) not M4 and DeWalt 611 router, except the following topic: Routers and bits that can be usted on the maslow 4
For what I understand, the optimal feed rate for M4 is around 2000 mm/min.
- The formula I’ve found is something like that:
feedrate = chipload * 25.4 * rpm * no_flutes - I’ve read an upcut bit is recommended but couldn’t a compression bit be more easier to use (Clean edge on both sides) ? Like this one which was previously on the store.
- Recommended bit seems to be 1/8" single-flute upcut ;
- Chipload for MDF/Plywood is
0.004 - 0.007so RPM should be around 14k RPM. Do you confirm ? If so, how to set correct RPM on DeWalt Router ? - Maximum depth for each pass should be half the bit diameter, so 1/16" (1.6mm). Right ?
- A candidate would be this bit: https://www.aliexpress.com/item/1005001948417279.html (DSP1F-D3.1-L17) ;
- The bigger the bit, the faster and the deeper I can go ?
Do you have any recommandations where to buy bits ? Such as https://www.aliexpress.com/item/1005002803507494.html ?
What kind of set (V-Carve bit) would you recommend if I’d also like to create signs for example ?
EDIT:
Old Maslow shop had the following items. Are these advice still valid ?
Solid Tungsten Carbide ¼ Inch 2 Flute Up-spiral Bit
This is the basic bit that we’ve been recommending when we get the question “Which bit should I use?” It’s versatile, very forgiving, and works well with most materials. This is a good bit to start with. -
Solid Tungsten Carbide ¼ Inch Single Flute Up-spiral Bit
Similar to the the Tungsten Carbide 2 Flute Up-spiral Bit, but with only a single flute. Using a single flute means that for the same rotation speed and forward speed as the two flute bit, the single flute takes twice as big of a “bite” with each rotation. This can give you a cleaner cut or reduce burning in some materials. -
Solid Tungsten Carbide ¼ Inch 2 Flute Compression Bit
A compression bit is designed specifically to reduce a phenomenon called “tear out” which is caused when the upwards or downwards spiral of a router bit leaves a chipped or fuzzy edge on either the top or bottom of a cut because of the aggressive action of the spiral. A compression bit solves this issue by being a down spiral bit on the top, and an up spiral bit on the bottom which compresses both edges of the wood towards the center leaving a smooth cut on both the top and bottom.
Thanks for your time
