So if I buy for example the maker made maslow version 1 or the metal maslow; what else is required?
- I would need the wood frame obviously.
- I would need extension chains
Is this is? cuz if the m2 upgrade is mainly the Z and I can do that diy myself
otherwise than I think saving myself half the cost is worth it since it
honestly doesnt matter how slow this thing is, it only matters how accurate it
is.
accuracy vs precision
The maslows are all very precise, they will repeat the exact same cut with very
good accuracy (as long as the sled doesn’t stick, which is the issue in the
bottom corners)
accuracy is that the cuts that the maslow makes are all straight and where you
expect them to be based on the g-code. This is not as good, there are a LOT of
sources of possible error (look up the thread ‘sources of error’) and many of
them are not addressed in any current firmware. That said, most of them are
small enough that people don’t notice them, but it is going to depend on how
accurate you need it to be. The errors are not consistant across the workspace,
so if you get it dialed in in the center, and then move to a different part of
the workspace, the errors will be different. The holey calibration (in
webcontrol) seems to be the best option (excluding the M2 that I don’t know
about)
So that makes me wonder if it matters if I grab the maker made or metal maslow
version, the metal maslow claims to have faster motors but from what I’m
reading going slower gives better accuracy so this isn’t even needed?
it’s not better accuracy everywhere, but it can affect you
I’d like to fully know what I’m getting myself into before I drop nearly 800
canadian on the OG model, cuz the m2 model would be nearly 2 grand by the time
it got here… would be good to know how what things need to be added or
replaced on the og model cost wise…
The Z axis is the weak link of the original maslow, you will want to improve
that. going with a wider top beam is good (and a little higher from the
workpiece is good), and finally, when you get really close to the edges and
bottom, you will want to add skirts to support the sled and keep it from
tipping off the edge (most important at the bottom) but other than that, they
work well.
You will want to check in before you mount the top beam and after you build the
sled so that you can mount the top beam at the right distance out from the
workpiece. The frame instructions end up putting it a bit too far out, which you
can compensate for by putting a spacer behind your workpiece.
Kinda leaning towards the metal maslow cuz it comes with a router that its
made to be used with and I like the idea of the metal weight for the sled
instead of straps and bricks… but I guess at the end of the day it doesnt
matter as long as the sled is slick and weighted…
weights you can source locally rather than having to pay for them to be shipped
internationally
