Hi. I think the initialization of the first guess is odd. If you take a look into the calibration simulation there are two lines:
guessThisTime.br.x = guessThisTime.bl.x + (Math.random() * 400) - 200;
guessThisTime.br.y = guessThisTime.bl.y + (Math.random() * 400) - 200;
which means that the bottom right becomes the initial values of the bottom left. This can lead to non convergence but at least the convergence becomes very slow. Attach Maslow-serial(28).log (119.5 KB)
I think this is also done by the common calibration. If you take a look onto the initial 3x3 calibration result, the initial fitness is very low and takes a long time until if becomes meaningful. My setting is 3.5 m x 2.5 m at a concrete floor.
That is interesting! Thank you for pointing that out!
Iām not totally sure that the simulation code works the same as the calibration code, but they should be quite similar. Giving it a quick look through it seems like that bug is just in the simulator.
Here is the version running during calibration on the machine:
