Thanks. I re-measured, and attempted to get through the configuration again. My frame size is 12’Wx8’H. It made it trough a good amount of the calibration process but again said Fitness Too Low.
Not sure how to get this calibrated? Can I use it even if it will not calibrate? It seems to move around fine now.
Here is the output from the calibration process:
[MSG:INFO: Zeroing z-axis position]
[MSG:INFO: Center point deviation: TL: 0.103 TR: 0.200 BL: -55.322 BR: 33.086]
CLBM:[{bl:2142.88, br:2232.41, tr:2198.86, tl:2200.32},{bl:2131.46, br:2132.64, tr:2218.55, tl:2304.16},{bl:1921.35, br:2377.41, tr:2422.96, tl:2076.04},{bl:1945.04, br:2447.30, tr:2410.61, tl:1997.36},{bl:2023.96, br:2510.67, tr:2349.85, tl:1923.66},{bl:2212.37, br:2271.07, tr:2132.04, tl:2165.23},{bl:2421.08, br:2075.11, tr:1921.94, tl:2377.71},{bl:2410.18, br:1996.36, tr:1943.66, tl:2448.45},{bl:2349.43, br:1922.65, tr:2022.02, tl:2512.06},]
Computing... This may take several minutesFitness: 0.6682288 in 100
Fitness: 1.3703152 in 200
Fitness: 1.3877602 in 300
Fitness: 1.3961764 in 400
Fitness: 1.4054266 in 500
Fitness: 1.4141936 in 600
Fitness: 1.4208036 in 700
Fitness: 1.4253967 in 800
Fitness: 1.4295141 in 900
Fitness: 1.4334141 in 1000
Fitness: 1.4369718 in 1100
Fitness: 1.4407747 in 1200
Fitness: 1.4437860 in 1300
Fitness: 1.4464897 in 1400
Fitness: 1.4488409 in 1500
Fitness: 1.4506955 in 1600
Fitness: 1.4523506 in 1700
Fitness: 1.4536658 in 1800
Fitness: 1.4552856 in 1900
Fitness: 1.4568999 in 2000
Fitness: 1.4585261 in 2100
Fitness: 1.4600371 in 2200
Fitness: 1.4616306 in 2300
Fitness: 1.4634348 in 2400
Fitness: 1.4640276 in 2500
Fitness: 1.4640569 in 2600
Fitness: 1.4640569 in 2700
Fitness: 1.4640569 in 2800
Fitness: 1.4640569 in 2900
Fitness: 1.4640569 in 3000
Fitness: 1.4640569 in 3100
Fitness: 1.4640613 in 3200
Fitness: 1.4640745 in 3300
Fitness: 1.4640745 in 3400
Fitness: 1.4640745 in 3500
Fitness: 1.4640745 in 3600
Fitness: 1.4640745 in 3700
Fitness: 1.4640745 in 3800
Fitness: 1.4640745 in 3900
Fitness: 1.4640745 in 4000
Fitness: 1.4640745 in 4100
Fitness: 1.4640745 in 4200
Calibration complete
Calibration values:
Fitness: 1.4640746104134064
Maslow_tlX: -54.7
Maslow_tlY: 2443.5
Maslow_trX: 3593.8
Maslow_trY: 2438.7
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3644.5
Maslow_brY: 0.0
These values have been automatically saved for you.
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
CLBM:[{bl:2142.88, br:2232.41, tr:2198.86, tl:2200.32},{bl:2131.46, br:2132.64, tr:2218.55, tl:2304.16},{bl:1921.35, br:2377.41, tr:2422.96, tl:2076.04},{bl:1945.04, br:2447.30, tr:2410.61, tl:1997.36},{bl:2023.96, br:2510.67, tr:2349.85, tl:1923.66},{bl:2212.37, br:2271.07, tr:2132.04, tl:2165.23},{bl:2421.08, br:2075.11, tr:1921.94, tl:2377.71},{bl:2410.18, br:1996.36, tr:1943.66, tl:2448.45},{bl:2349.43, br:1922.65, tr:2022.02, tl:2512.06},{bl:2266.04, br:1870.08, tr:2132.93, tl:2565.70},{bl:2043.07, br:2085.96, tr:2319.11, tl:2369.19},{bl:1826.93, br:2310.44, tr:2517.10, tl:2179.28},{bl:1620.60, br:2538.88, tr:2724.56, tl:2002.65},{bl:1699.73, br:2587.48, tr:2661.00, tl:1912.60},{bl:1781.72, br:2641.26, tr:2600.14, tl:1826.64},{bl:1870.44, br:2700.18, tr:2543.93, tl:1745.40},{bl:1962.60, br:2764.89, tr:2492.74, tl:1669.55},{bl:2132.42, br:2561.87, tr:2264.69, tl:1878.38},{bl:2320.68, br:2361.63, tr:2041.64, tl:2093.87},{bl:2518.87, br:2171.72, tr:1825.57, tl:2317.65},{bl:2723.67, br:1995.17, tr:1619.37, tl:2545.09},{bl:2662.57, br:1904.94, tr:1698.93, tl:2594.82},{bl:2601.69, br:1818.97, tr:1782.06, tl:2649.45},{bl:2545.46, br:1737.57, tr:1867.81, tl:2708.33},{bl:2494.25, br:1661.65, tr:1959.41, tl:2773.06},]
Computing... This may take several minutesFitness: 0.8428446 in 100
Fitness: 0.8428446 in 200
Fitness: 0.8428446 in 300
Fitness: 0.8428446 in 400
Fitness: 0.8428446 in 500
Fitness: 0.8428446 in 600
Fitness: 0.8428446 in 700
Fitness: 0.8428446 in 800
Fitness: 0.8428446 in 900
Fitness: 0.8428446 in 1000
Calibration values:
Fitness: 0.8428446242063459
Maslow_tlX: -54.7
Maslow_tlY: 2443.5
Maslow_trX: 3594.4
Maslow_trY: 2439.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3645.1
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Measured waypoint 48]
CLBM:[{bl:2142.88, br:2232.41, tr:2198.86, tl:2200.32},{bl:2131.46, br:2132.64, tr:2218.55, tl:2304.16},{bl:1921.35, br:2377.41, tr:2422.96, tl:2076.04},{bl:1945.04, br:2447.30, tr:2410.61, tl:1997.36},{bl:2023.96, br:2510.67, tr:2349.85, tl:1923.66},{bl:2212.37, br:2271.07, tr:2132.04, tl:2165.23},{bl:2421.08, br:2075.11, tr:1921.94, tl:2377.71},{bl:2410.18, br:1996.36, tr:1943.66, tl:2448.45},{bl:2349.43, br:1922.65, tr:2022.02, tl:2512.06},{bl:2266.04, br:1870.08, tr:2132.93, tl:2565.70},{bl:2043.07, br:2085.96, tr:2319.11, tl:2369.19},{bl:1826.93, br:2310.44, tr:2517.10, tl:2179.28},{bl:1620.60, br:2538.88, tr:2724.56, tl:2002.65},{bl:1699.73, br:2587.48, tr:2661.00, tl:1912.60},{bl:1781.72, br:2641.26, tr:2600.14, tl:1826.64},{bl:1870.44, br:2700.18, tr:2543.93, tl:1745.40},{bl:1962.60, br:2764.89, tr:2492.74, tl:1669.55},{bl:2132.42, br:2561.87, tr:2264.69, tl:1878.38},{bl:2320.68, br:2361.63, tr:2041.64, tl:2093.87},{bl:2518.87, br:2171.72, tr:1825.57, tl:2317.65},{bl:2723.67, br:1995.17, tr:1619.37, tl:2545.09},{bl:2662.57, br:1904.94, tr:1698.93, tl:2594.82},{bl:2601.69, br:1818.97, tr:1782.06, tl:2649.45},{bl:2545.46, br:1737.57, tr:1867.81, tl:2708.33},{bl:2494.25, br:1661.65, tr:1959.41, tl:2773.06},{bl:2448.56, br:1592.41, tr:2053.41, tl:2839.77},{bl:2215.71, br:1810.62, tr:2217.47, tl:2643.14},{bl:1987.00, br:2031.86, tr:2397.94, tl:2448.94},{bl:1763.98, br:2263.74, tr:2590.98, tl:2265.72},{bl:1549.32, br:2496.53, tr:2792.12, tl:2096.38},{bl:1346.80, br:2729.25, tr:3001.09, tl:1944.56},{bl:1429.24, br:2769.31, tr:2940.37, tl:1843.17},{bl:1517.80, br:2814.50, tr:2879.97, tl:1744.87},{bl:1609.00, br:2864.31, tr:2823.78, tl:1650.18},{bl:1706.21, br:2920.09, tr:2772.13, tl:1559.77},{bl:1805.62, br:2980.03, tr:2725.23, tl:1474.43},{bl:1908.45, br:3040.44, tr:2683.32, tl:1395.11},{bl:2054.89, br:2838.89, tr:2447.48, tl:1600.09},{bl:2219.12, br:2635.95, tr:2214.58, tl:1815.32},{bl:2401.01, br:2441.74, tr:1985.83, tl:2039.13},{bl:2591.91, br:2258.53, tr:1762.93, tl:2268.32},{bl:2793.55, br:2089.24, tr:1548.29, tl:2499.29},{bl:3000.28, br:1937.59, tr:1345.93, tl:2732.36},{bl:2941.70, br:1836.04, tr:1429.13, tl:2772.98},{bl:2881.29, br:1737.62, tr:1515.92, tl:2820.24},{bl:2825.10, br:1642.71, tr:1609.41, tl:2870.90},{bl:2773.43, br:1552.18, tr:1703.85, tl:2927.15},{bl:2726.51, br:1466.72, tr:1803.66, tl:2985.59},{bl:2684.56, br:1387.26, tr:1906.66, tl:3049.14},]
Computing... This may take several minutesFitness: 0.5932108 in 100
Fitness: 0.5932108 in 200
Fitness: 0.5932108 in 300
Fitness: 0.5932108 in 400
[MSG:ERR: Calibration data not acknowledged by computer, resending]Fitness: 0.5932108 in 500
Computing... This may take several minutesFitness: 0.5932108 in 600
Fitness: 0.5932108 in 700
Fitness: 0.5932108 in 800
Fitness: 0.5932108 in 900
Fitness: 0.5932108 in 1000
Calibration values:
Fitness: 0.5932107973381919
Maslow_tlX: -54.7
Maslow_tlY: 2443.5
Maslow_trX: 3594.4
Maslow_trY: 2439.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3645.3
Maslow_brY: 0.0
These values have been automatically saved for you.Fitness: 0.5932108 in 400
[MSG:INFO: Zeroing z-axis position]Fitness: 0.5932108 in 800
Calibration values:
Maslow_tlX: -54.7
Maslow_tlY: 2443.5
Maslow_trX: 3594.4
Maslow_trY: 2439.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3645.3
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 49]
[MSG:INFO: Measured waypoint 50]
[MSG:INFO: Measured waypoint 51]
[MSG:INFO: Measured waypoint 52]
[MSG:INFO: Measured waypoint 53]
[MSG:INFO: Measured waypoint 54]
[MSG:INFO: Measured waypoint 55]
[MSG:INFO: Measured waypoint 56]
[MSG:INFO: Measured waypoint 57]
[MSG:INFO: Measured waypoint 58]
[MSG:INFO: Measured waypoint 59]
[MSG:INFO: Measured waypoint 60]
[MSG:INFO: Measured waypoint 61]
[MSG:INFO: Measured waypoint 62]
[MSG:INFO: Measured waypoint 63]
[MSG:INFO: Measured waypoint 64]
[MSG:INFO: Measured waypoint 65]
[MSG:INFO: Measured waypoint 66]
[MSG:INFO: Measured waypoint 67]
[MSG:INFO: Measured waypoint 68]
[MSG:INFO: Measured waypoint 69]
[MSG:INFO: Measured waypoint 70]
[MSG:INFO: Measured waypoint 71]
[MSG:INFO: Measured waypoint 72]
[MSG:INFO: Measured waypoint 73]
[MSG:INFO: Measured waypoint 74]
[MSG:INFO: Measured waypoint 75]
[MSG:INFO: Measured waypoint 76]
[MSG:INFO: Measured waypoint 77]
[MSG:INFO: Measured waypoint 78]
[MSG:INFO: Measured waypoint 79]
[MSG:INFO: Measured waypoint 80]
CLBM:[{bl:2142.88, br:2232.41, tr:2198.86, tl:2200.32},{bl:2131.46, br:2132.64, tr:2218.55, tl:2304.16},{bl:1921.35, br:2377.41, tr:2422.96, tl:2076.04},{bl:1945.04, br:2447.30, tr:2410.61, tl:1997.36},{bl:2023.96, br:2510.67, tr:2349.85, tl:1923.66},{bl:2212.37, br:2271.07, tr:2132.04, tl:2165.23},{bl:2421.08, br:2075.11, tr:1921.94, tl:2377.71},{bl:2410.18, br:1996.36, tr:1943.66, tl:2448.45},{bl:2349.43, br:1922.65, tr:2022.02, tl:2512.06},{bl:2266.04, br:1870.08, tr:2132.93, tl:2565.70},{bl:2043.07, br:2085.96, tr:2319.11, tl:2369.19},{bl:1826.93, br:2310.44, tr:2517.10, tl:2179.28},{bl:1620.60, br:2538.88, tr:2724.56, tl:2002.65},{bl:1699.73, br:2587.48, tr:2661.00, tl:1912.60},{bl:1781.72, br:2641.26, tr:2600.14, tl:1826.64},{bl:1870.44, br:2700.18, tr:2543.93, tl:1745.40},{bl:1962.60, br:2764.89, tr:2492.74, tl:1669.55},{bl:2132.42, br:2561.87, tr:2264.69, tl:1878.38},{bl:2320.68, br:2361.63, tr:2041.64, tl:2093.87},{bl:2518.87, br:2171.72, tr:1825.57, tl:2317.65},{bl:2723.67, br:1995.17, tr:1619.37, tl:2545.09},{bl:2662.57, br:1904.94, tr:1698.93, tl:2594.82},{bl:2601.69, br:1818.97, tr:1782.06, tl:2649.45},{bl:2545.46, br:1737.57, tr:1867.81, tl:2708.33},{bl:2494.25, br:1661.65, tr:1959.41, tl:2773.06},{bl:2448.56, br:1592.41, tr:2053.41, tl:2839.77},{bl:2215.71, br:1810.62, tr:2217.47, tl:2643.14},{bl:1987.00, br:2031.86, tr:2397.94, tl:2448.94},{bl:1763.98, br:2263.74, tr:2590.98, tl:2265.72},{bl:1549.32, br:2496.53, tr:2792.12, tl:2096.38},{bl:1346.80, br:2729.25, tr:3001.09, tl:1944.56},{bl:1429.24, br:2769.31, tr:2940.37, tl:1843.17},{bl:1517.80, br:2814.50, tr:2879.97, tl:1744.87},{bl:1609.00, br:2864.31, tr:2823.78, tl:1650.18},{bl:1706.21, br:2920.09, tr:2772.13, tl:1559.77},{bl:1805.62, br:2980.03, tr:2725.23, tl:1474.43},{bl:1908.45, br:3040.44, tr:2683.32, tl:1395.11},{bl:2054.89, br:2838.89, tr:2447.48, tl:1600.09},{bl:2219.12, br:2635.95, tr:2214.58, tl:1815.32},{bl:2401.01, br:2441.74, tr:1985.83, tl:2039.13},{bl:2591.91, br:2258.53, tr:1762.93, tl:2268.32},{bl:2793.55, br:2089.24, tr:1548.29, tl:2499.29},{bl:3000.28, br:1937.59, tr:1345.93, tl:2732.36},{bl:2941.70, br:1836.04, tr:1429.13, tl:2772.98},{bl:2881.29, br:1737.62, tr:1515.92, tl:2820.24},{bl:2825.10, br:1642.71, tr:1609.41, tl:2870.90},{bl:2773.43, br:1552.18, tr:1703.85, tl:2927.15},{bl:2726.51, br:1466.72, tr:1803.66, tl:2985.59},{bl:2684.56, br:1387.26, tr:1906.66, tl:3049.14},{bl:2647.98, br:1315.05, tr:2006.71, tl:3116.26},{bl:2408.42, br:1530.89, tr:2148.88, tl:2918.11},{bl:2171.33, br:1753.70, tr:2304.45, tl:2720.56},{bl:1937.26, br:1983.76, tr:2480.82, tl:2532.32},{bl:1707.73, br:2218.73, tr:2667.46, tl:2355.58},{bl:1484.86, br:2455.42, tr:2865.05, tl:2193.16},{bl:1272.20, br:2692.75, tr:3067.79, tl:2048.56},{bl:1075.58, br:2939.98, tr:3278.02, tl:1925.48},{bl:1165.79, br:2965.28, tr:3219.32, tl:1814.48},{bl:1259.43, br:3001.27, tr:3159.31, tl:1705.48},{bl:1358.32, br:3044.64, tr:3103.14, tl:1598.69},{bl:1459.85, br:3091.45, tr:3051.10, tl:1494.80},{bl:1567.39, br:3140.97, tr:3003.35, tl:1394.35},{bl:1675.71, br:3201.87, tr:2960.10, tl:1298.04},{bl:1787.42, br:3256.92, tr:2921.58, tl:1207.21},{bl:1895.54, br:3318.74, tr:2887.94, tl:1122.91},{bl:2008.78, br:3116.20, tr:2646.79, tl:1322.67},{bl:2150.04, br:2911.10, tr:2407.22, tl:1538.40},{bl:2310.15, br:2713.55, tr:2170.00, tl:1761.93},{bl:2484.34, br:2525.29, tr:1935.98, tl:1991.72},{bl:2670.07, br:2348.59, tr:1706.55, tl:2225.16},{bl:2866.49, br:2186.30, tr:1483.80, tl:2461.26},{bl:3069.55, br:2041.75, tr:1271.28, tl:2699.18},{bl:3277.00, br:1919.14, tr:1074.81, tl:2936.13},{bl:3220.80, br:1807.91, tr:1163.20, tl:2968.48},{bl:3160.78, br:1698.59, tr:1257.26, tl:3007.34},{bl:3104.60, br:1591.66, tr:1356.44, tl:3048.19},{bl:3052.54, br:1487.56, tr:1457.64, tl:3096.11},{bl:3004.78, br:1386.89, tr:1562.02, tl:3148.06},{bl:2961.50, br:1290.48, tr:1668.76, tl:3204.19},{bl:2922.96, br:1199.40, tr:1779.48, tl:3263.42},{bl:2889.30, br:1114.89, tr:1890.67, tl:3327.74},]
Computing... This may take several minutesFitness: 0.4527757 in 100
Fitness: 0.4527757 in 200
Fitness: 0.4527757 in 300
Fitness: 0.4527757 in 400
Fitness: 0.4527757 in 500
Fitness: 0.4527757 in 600
Fitness: 0.4527757 in 700
Fitness: 0.4527757 in 800
Fitness: 0.4527757 in 900
Fitness: 0.4527757 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
