Hey, I wanted to share my dust collector file in case others wanted to use! I used the Maslow for about a month before i really got frustrated with the Z-axis issues. I took a lot of great advice and knowledge from this forum and then rebuilt my sled on a leftover sheet of plywood + HDPE and most importantly a C-Beam. I designed up some brackets to match up with my Ridgid router and then designed a dust collector to screw onto my sled and wrap around my C-Beam. This is hooked up to my Shopvac. 3D printed the collector out of PLA @ 80% infill (0.2 mm layers) and have had no issues. Does a pretty good job of getting all the saw dust. The only issue I had was removing the support material from inside, long pair of pliers is a must. .Stl file attached. It was designed around a Ridgid vaccumm hose at 1.25" OD (so dust collector is tapered 1.25" ID of course).
vaccuum attachment.STL (1.1 MB)Sean
