Hi,
I had an issue when issuing the retract all w/ only 2 cables retracting. After I bumped the current from 1300 to 1800, they all retracted.
I am on version 0.67 of f/w.
My first issue was that with a wooden frame of 10’x8’ my and the settings recommended in the video that my cables were super tight. They were so tight that it pulls the frame off the plywood on the top by about 1" on the top left and 1/2" off the plywood on the upper right.
I had some issues during calibration in the vertical configuration. I started with an angle of about 20 degrees off vertical and the upper left portion of the sled would pull about 1" off the plywood. The top right was about half of that. I tried increasing the angle off vertical to 35 degrees off vertical and it did the same thing.
I interrupted my calibration during the first pass on the left side to change the angle from 20 to 35 degrees off vertical. The calibration routine did not start again from the beginning (lower left) but continued from where it left off.
My final calibration results were deemed to be unusable. Here is the report:
Fitness: 0.4267775381206733 in 92700 cycles
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
Calibration complete
Calibration values:
Maslow_tlX: -12.8
Maslow_tlY: 2422.8
Maslow_trX: 2937.8
Maslow_trY: 2415.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 2940.5
Maslow_brY: 0.0
I did not change the current setting back from 1800 to 1300. Could this be part of the issue?
My last issue was that the sled was too high. The center of the sled would go about 1-2 " past the top of the plywood (which is centered) on the top and would only go down to about 1 foot from the bottom.
There is probably an offset to fix this??
Any suggestions would be appreciated.
Thanks!
