Hi All,
I finally have my Maslow setup and running. I have run the calibration several times already, (feels like groundhog day every time) reinforced the top beam to reduce flex, fairly stiff now and introduced the weighted chain tension system.
I was running my first test cuts for a project utilising a 3mm MDF sheet (because it’s cheaper than an $80 18mm birch sheet) and I have found it is cutting outside of the work area to 10mm below bottom edge) when the actual height of the drawing (1219.2mm) should fall just inside the edge of the work area.
What am I doing wrong? Is there a way to correct this? Is it rotational radius or distance between motors?
Thanks y’all in advance.
My MakerMade Ring Maslow 12 foot setup is as follows;
Measured distance between motor shafts (centres) = 3580mm +/- 0.5
Calibrated distance between motors = 3561.32
Measured Motor Vertical Offset = 565-568mm
Calibrated Vertical Offset = 566.4
Measured work area = 2444mm x 1223mm
Triangulation System
Bottom Feed
Calibrated Rotation Radius = 133.8
Calibrated Chain Sag = 29.490565
Calibration Benchmark Test Results
Small squares Width = Perfect
Small squares Height = 1.125 Avg
Horizontal Measurements = 0.5 Avg
Vertical Measurements = 9.83333333 Avg
Calibration Benchmark Test Actual Measurements
Square top left = 100 x 101.5
Square Top right = 100 x101.5
Square bot left = 100 x 101
Square bot right = 100 x 100.5
top horizontal = 1904.5
Centre Horizontal = 1904.5
bot horizontal = 1905
Vertical Left = 910
Vertical Centre = 910.5
Vertical Right = 909
Other Details
Ground Control v1.26
MacOS
Sled Diameter 16”
Sled thickness 16mm (Melamine)
Router and Ring hardware centered
Sled weight = 9.5kg (20.94lb)
Frame Angle = 15 degrees
Wasteboard 18mm MDF
