Hello I’m new to this world and just got my @EastBaySource maslow today and i’ts been kiling me, can’t manage to calibrate it. any tips or advices ? I get this message ‘‘the machine was not able to be calibrated’’ and the cut pattern horizontal is really weird I’ll attach some photos
thanks for the help in advance.
att.
javier vallejo
Hi Javier
Your settings are a bit off
It should be close to the following values
Distance between motors: 3008mm
Vertical offset: 300mm
Kinematics
Chain feed
Rotational radius: 140mm
Please let us know if it helps
I’ll measure them with a tape and got something like what you told me @EastBaySource everytime I do the ‘‘pull the chain’’ I get 2.40 something on the reading. changed it manually but the vertical offset I just Re-made it and it’s 450mm. don’t know if tha’s any problem.
Vertical offset is not a critical measure for calibration, it just moves the home position up/down.
Make sure your rotational radius is 140mm
Great, thanks for the help it just worked out great. I’m about to cut the final sled.
