I’ve been trying to calibrate for a 4’x8’ sheet of ply. Even with 9x9 I was not able to calibrate on the dimensions of a full sheet of ply. I could do 1000mm x 2000mm but that’s far short of 1219mm x 2438mm.
Does the calibration boundary define the outer boundary of the cutting area?
That is, if I calibrate for 1000x2000 can I still cut pieces that are larger?
Cutting full sheets has been an ambition of mine from the start.
what is your frame size? it may be that you are trying to calibrate in an area
where the arms hit the uprights
no, it’s just the area used for the calibration, it shoud be conservatively
inside the area where the arms do not hit the uprights (the green area in the
frame size calculators, mine is at http://lang.hm/maslow/maslow4_frame.html I
don’t have the link to Bar’s handy)
@DLang, I don’t remember where this calculator can be found.
In the past I remember having seen published examples.
Is it somewhere on a web page for us all to access?
