This process I know from 3D-printers. I asked because I pondered how important the height of the spools is for an accurate calibration. I know it would be better to have the anchor points slightly beneath the height of the spools, but the weight of the sled is easily high enough to have enough down force. Otherwise the vertical orientation wouldn’t work at all?!
@WFD Wow, this is above my payroll! ![]()
I somewhere put my exakt frame dimensions in this thread. When I come from work today I will measure all distances with my laser and will report them alongside the values of the calibration. ![]()
Width 4260mm x Height 2490mm. It’s now too late to make the measurements. I will do it tommorow.
There are a lot of libraries we could use but bringing in anything like that might require some changes to the UI because it seems like we are pretty close to the size limit on what we currently have. I know we don’t have internet access guarantee so we can’t load them from external sites like a lot of web apps do, or like I did on the standalone site.
True, but I intend to use a tape measure and get someone to help me, along with a few stools or stepladders.
Results with 0.69 firmware.
Serial Messages
[MSG:INFO: Bottom Right pulled tight with offset 0.000]
[MSG:INFO: Bottom Left pulled tight with offset 0.011]
[MSG:INFO: Top Left pulled tight with offset 0.000]
[MSG:INFO: Top Right pulled tight with offset -0.054]
[MSG:INFO: Point: 0 (0, 0)]
[MSG:INFO: Point: 1 (0, -150.000)]
[MSG:INFO: Point: 2 (-150.000, -150.000)]
[MSG:INFO: Point: 3 (-150.000, 0.000)]
[MSG:INFO: Point: 4 (-150.000, 150.000)]
[MSG:INFO: Point: 5 (0.000, 150.000)]
[MSG:INFO: Point: 6 (0.000, 0.000)]
[MSG:INFO: Point: 7 (0.000, -150.000)]
[MSG:INFO: Point: 8 (150.000, -150.000)]
[MSG:INFO: Point: 9 (150.000, 0.000)]
[MSG:INFO: Point: 10 (150.000, 150.000)]
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Calibration complete]
CLBM:[{bl:1923.25, br:2402.30, tr:2608.70, tl:2033.27},{bl:1709.67, br:2369.56, tr:2712.18, tl:2151.01},{bl:1583.45, br:2517.82, tr:2834.79, tl:2039.90},{bl:1694.85, br:2565.99, tr:2736.18, tl:1928.00},{bl:1795.76, br:2632.56, tr:2662.24, tl:1821.58},{bl:1906.23, br:2496.95, tr:2531.06, tl:1939.34},{bl:1791.74, br:2429.44, tr:2628.95, tl:2045.33},{bl:1709.67, br:2369.59, tr:2711.77, tl:2150.49},{bl:1858.55, br:2231.28, tr:2571.64, tl:2248.88},{bl:1937.47, br:2299.94, tr:2483.78, tl:2143.46},{bl:2025.68, br:2375.27, tr:2402.10, tl:2048.27},]
Computing… This may take several minutesFitness: 0.1243514 in 100
Fitness: 0.1243514 in 200
Fitness: 0.1243514 in 300
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
Calibration values:
Fitness: 0.12435135380510604
Maslow_tlX: -6.6
Maslow_tlY: 2438.4
Maslow_trX: 3693.4
Maslow_trY: 2438.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3669.2
Maslow_brY: 0.0
@bar it seems to let out much more belt towards the right of the machine than the left at the start. The top right belt doesn’t get tight at the first point. All belts are tight at other points. The prior iterations had 0,0,0 basically correct just from eyeballing it.
I was really hoping this would allow me to at least calibrate with a small point matrix but it doesn’t seem to be the case.
Repeat also yields the similar poor results.
Serial Messages
Calibration values:
Maslow_tlX: -6.6
Maslow_tlY: 2438.4
Maslow_trX: 3693.4
Maslow_trY: 2438.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3669.2
Maslow_brY: 0.0
Running the maslow logo g code keeps all the belts tight through the cut however you can see it surge as it changes speed and clearly isn’t smooth. It failed on the second pass through the logo i believe.
Again tested an extend, retract, extend, retract and all seems good on that front with good ~0 offsets.
[MSG:INFO: Bottom Left pulled tight with offset 0.000]
[MSG:INFO: Top Right pulled tight with offset 0.054]
[MSG:INFO: Bottom Right pulled tight with offset 0.032]
[MSG:INFO: Top Left pulled tight with offset 0.150]
[MSG:INFO: Top Right pulled tight with offset 0.000]
[MSG:INFO: Bottom Left pulled tight with offset 0.161]
Re ran again this morning by.
- Retract
- Extend.
- Tension.
- Calibrate
Centerpoint is roughly in the center this way by eyeing prior to calibration starting. Calibration is happening over the center point.
3x3 300mm x 30mm Matrix
Serial Messages
[MSG:INFO: Top Right pulled tight with offset -0.011]
[MSG:INFO: Bottom Right pulled tight with offset -0.032]
[MSG:INFO: Top Left pulled tight with offset -0.011]
[MSG:INFO: Center point deviation: TL: -0.006 TR: 0.108 BL: 20.387 BR: 12.937]
[MSG:ERR: Center point deviation over 15.000mmm, your coordinate system is not accurate, maybe try running calibration again?]
CLBM:[{bl:2221.31, br:2217.43, tr:2200.11, tl:2202.63},{bl:2119.82, br:2121.69, tr:2307.32, tl:2303.23},{bl:1991.85, br:2265.17, tr:2427.05, tl:2171.26},{bl:2099.89, br:2338.88, tr:2326.31, tl:2079.90},{bl:2196.95, br:2425.06, tr:2251.30, tl:1995.66},{bl:2307.93, br:2287.54, tr:2120.65, tl:2142.85},{bl:2199.23, br:2201.03, tr:2221.89, tl:2219.21},{bl:2119.85, br:2121.70, tr:2306.98, tl:2303.10},{bl:2268.28, br:1993.85, tr:2168.54, tl:2423.82},{bl:2343.70, br:2096.20, tr:2077.17, tl:2328.75},{bl:2429.06, br:2192.86, tr:1992.83, tl:2253.88},]
Computing… This may take several minutesFitness: 0.8161478 in 100
Fitness: 1.6490797 in 200
Fitness: 1.6535775 in 300
Fitness: 1.6568823 in 400
Fitness: 1.6599386 in 500
Fitness: 1.6626521 in 600
Fitness: 1.6652833 in 700
Fitness: 1.6676224 in 800
Fitness: 1.6698867 in 900
Fitness: 1.6706333 in 1000
Fitness: 1.6706333 in 1100
Fitness: 1.6706333 in 1200
Fitness: 1.6706333 in 1300
Calibration values:
Fitness: 1.6706333070152901
Maslow_tlX: -23.9
Maslow_tlY: 2437.4
Maslow_trX: 3686.8
Maslow_trY: 2438.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3661.8
Maslow_brY: 0.0
These values have been automatically saved for you.
You MUST restart your machine for them to take effect…I know that is annoying, it’s getting fixed ASAP.
Running another calibration matrix 5x5 at 500mm x 500mm using the prior values as the starting Maslow.yaml points. Yields the following results.
Calibration Value Comparison
0.68 - 3x3 300x300
Calibration values:
Fitness: 1.2571441933075425
Maslow_tlX: -22.8
Maslow_tlY: 2176.7
Maslow_trX: 3843.4
Maslow_trY: 2186.2
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3822.3
Maslow_brY: 0.0
0.69 - 3x3 300x300
Calibration values:
Maslow_tlX: -23.9
Maslow_tlY: 2437.4
Maslow_trX: 3686.8
Maslow_trY: 2438.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3661.8
Maslow_brY: 0.0
0.69 - 5x5 500x500
Calibration values:
Fitness: 0.9332424604041556
Maslow_tlX: -22.8
Maslow_tlY: 2437.4
Maslow_trX: 3686.8
Maslow_trY: 2438.6
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3662.9
Maslow_brY: 0.0
Full Log
Serial Messages
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Set to comply]
[MSG:INFO: Top Right pulled tight with offset -1839.424]
[MSG:INFO: Bottom Right pulled tight with offset -2039.384]
[MSG:INFO: Top Left pulled tight with offset -2100.450]
[MSG:INFO: Bottom Left pulled tight with offset -2275.610]
[MSG:INFO: Point: 1 (0, -250.000)]
[MSG:INFO: Point: 2 (-250.000, -250.000)]
[MSG:INFO: Point: 3 (-250.000, -125.000)]
[MSG:INFO: Point: 4 (-250.000, 0.000)]
[MSG:INFO: Point: 5 (-250.000, 125.000)]
[MSG:INFO: Point: 6 (-250.000, 250.000)]
[MSG:INFO: Point: 7 (-125.000, 250.000)]
[MSG:INFO: Point: 8 (-125.000, 125.000)]
[MSG:INFO: Point: 9 (-125.000, 0.000)]
[MSG:INFO: Point: 10 (-125.000, -125.000)]
[MSG:INFO: Point: 11 (-125.000, -250.000)]
[MSG:INFO: Point: 12 (0.000, -250.000)]
[MSG:INFO: Point: 13 (0.000, -125.000)]
[MSG:INFO: Point: 14 (0.000, 0.000)]
[MSG:INFO: Point: 15 (0.000, 125.000)]
[MSG:INFO: Point: 16 (0.000, 250.000)]
[MSG:INFO: Point: 17 (125.000, 250.000)]
[MSG:INFO: Point: 18 (125.000, 125.000)]
[MSG:INFO: Point: 19 (125.000, 0.000)]
[MSG:INFO: Point: 20 (125.000, -125.000)]
[MSG:INFO: Point: 21 (125.000, -250.000)]
[MSG:INFO: Point: 22 (250.000, -250.000)]
[MSG:INFO: Point: 23 (250.000, -125.000)]
[MSG:INFO: Point: 24 (250.000, 0.000)]
[MSG:INFO: Point: 25 (250.000, 125.000)]
[MSG:INFO: Point: 26 (250.000, 250.000)]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
CLBM:[{bl:2183.10, br:2191.92, tr:2227.92, tl:2228.27},{bl:2069.09, br:2071.28, tr:2369.68, tl:2364.65},{bl:1851.59, br:2287.35, tr:2568.58, tl:2185.49},{bl:1915.47, br:2343.04, tr:2504.87, tl:2103.01},{bl:1987.72, br:2402.86, tr:2439.62, tl:2024.95},{bl:2068.02, br:2466.84, tr:2379.12, tl:1951.80},{bl:2148.62, br:2535.31, tr:2323.93, tl:1884.11},{bl:2242.31, br:2444.16, tr:2211.25, tl:1984.19},{bl:2167.96, br:2371.57, tr:2268.45, tl:2047.64},{bl:2093.35, br:2303.44, tr:2329.13, tl:2119.14},{bl:2023.72, br:2240.29, tr:2396.77, tl:2192.89},{bl:1959.38, br:2182.50, tr:2469.93, tl:2271.43},{bl:2068.85, br:2071.19, tr:2374.29, tl:2366.54},{bl:2129.02, br:2123.89, tr:2298.61, tl:2299.48},{bl:2194.07, br:2189.85, tr:2227.43, tl:2228.31},{bl:2264.73, br:2261.73, tr:2161.03, tl:2162.03},{bl:2337.82, br:2335.96, tr:2100.08, tl:2101.10},{bl:2436.89, br:2249.05, tr:1990.49, tl:2204.63},{bl:2369.67, br:2169.94, tr:2051.24, tl:2263.79},{bl:2301.57, br:2095.38, tr:2120.29, tl:2325.04},{bl:2238.33, br:2025.72, tr:2194.94, tl:2392.77},{bl:2180.38, br:1961.61, tr:2274.98, tl:2464.19},{bl:2290.12, br:1853.87, tr:2184.52, tl:2565.81},{bl:2352.10, br:1913.78, tr:2101.95, tl:2505.46},{bl:2407.18, br:1987.46, tr:2023.81, tl:2440.26},{bl:2469.81, br:2065.44, tr:1950.60, tl:2379.90},{bl:2537.77, br:2145.58, tr:1882.76, tl:2324.74},]
Computing… This may take several minutesFitness: 0.9279697 in 100
Fitness: 0.9303753 in 200
Fitness: 0.9320062 in 300
Fitness: 0.9330533 in 400
Fitness: 0.9332425 in 500
Fitness: 0.9332425 in 600
Fitness: 0.9332425 in 700
Calibration values:
Maslow_tlX: -22.8
Maslow_tlY: 2437.4
Maslow_trX: 3686.8
Maslow_trY: 2438.6
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3662.9
Maslow_brY: 0.0
9x9 1500 x 1000 Calibration
LOG
Serial Messages
[MSG:ERR: Cannot take slack until all axis are extended fully]
[MSG:INFO: Top Right pulled tight with offset -1729.497]
[MSG:INFO: Bottom Right pulled tight with offset -1992.166]
[MSG:INFO: Top Left pulled tight with offset -2171.352]
[MSG:INFO: Bottom Left pulled tight with offset -2384.334]
[MSG:INFO: Point: 1 (0, -500.000)]
[MSG:INFO: Point: 2 (-750.000, -500.000)]
[MSG:INFO: Point: 3 (-750.000, -375.000)]
[MSG:INFO: Point: 4 (-750.000, -250.000)]
[MSG:INFO: Point: 5 (-750.000, -125.000)]
[MSG:INFO: Point: 6 (-750.000, 0.000)]
[MSG:INFO: Point: 7 (-750.000, 125.000)]
[MSG:INFO: Point: 8 (-750.000, 250.000)]
[MSG:INFO: Point: 9 (-750.000, 375.000)]
[MSG:INFO: Point: 10 (-750.000, 500.000)]
[MSG:INFO: Point: 11 (-562.500, 500.000)]
[MSG:INFO: Point: 12 (-562.500, 375.000)]
[MSG:INFO: Point: 13 (-562.500, 250.000)]
[MSG:INFO: Point: 14 (-562.500, 125.000)]
[MSG:INFO: Point: 15 (-562.500, 0.000)]
[MSG:INFO: Point: 16 (-562.500, -125.000)]
[MSG:INFO: Point: 17 (-562.500, -250.000)]
[MSG:INFO: Point: 18 (-562.500, -375.000)]
[MSG:INFO: Point: 19 (-562.500, -500.000)]
[MSG:INFO: Point: 20 (-375.000, -500.000)]
[MSG:INFO: Point: 21 (-375.000, -375.000)]
[MSG:INFO: Point: 22 (-375.000, -250.000)]
[MSG:INFO: Point: 23 (-375.000, -125.000)]
[MSG:INFO: Point: 24 (-375.000, 0.000)]
[MSG:INFO: Point: 25 (-375.000, 125.000)]
[MSG:INFO: Point: 26 (-375.000, 250.000)]
[MSG:INFO: Point: 27 (-375.000, 375.000)]
[MSG:INFO: Point: 28 (-375.000, 500.000)]
[MSG:INFO: Point: 29 (-187.500, 500.000)]
[MSG:INFO: Point: 30 (-187.500, 375.000)]
[MSG:INFO: Point: 31 (-187.500, 250.000)]
[MSG:INFO: Point: 32 (-187.500, 125.000)]
[MSG:INFO: Point: 33 (-187.500, 0.000)]
[MSG:INFO: Point: 34 (-187.500, -125.000)]
[MSG:INFO: Point: 35 (-187.500, -250.000)]
[MSG:INFO: Point: 36 (-187.500, -375.000)]
[MSG:INFO: Point: 37 (-187.500, -500.000)]
[MSG:INFO: Point: 38 (0.000, -500.000)]
[MSG:INFO: Point: 39 (0.000, -375.000)]
[MSG:INFO: Point: 40 (0.000, -250.000)]
[MSG:INFO: Point: 41 (0.000, -125.000)]
[MSG:INFO: Point: 42 (0.000, 0.000)]
[MSG:INFO: Point: 43 (0.000, 125.000)]
[MSG:INFO: Point: 44 (0.000, 250.000)]
[MSG:INFO: Point: 45 (0.000, 375.000)]
[MSG:INFO: Point: 46 (0.000, 500.000)]
[MSG:INFO: Point: 47 (187.500, 500.000)]
[MSG:INFO: Point: 48 (187.500, 375.000)]
[MSG:INFO: Point: 49 (187.500, 250.000)]
[MSG:INFO: Point: 50 (187.500, 125.000)]
[MSG:INFO: Point: 51 (187.500, 0.000)]
[MSG:INFO: Point: 52 (187.500, -125.000)]
[MSG:INFO: Point: 53 (187.500, -250.000)]
[MSG:INFO: Point: 54 (187.500, -375.000)]
[MSG:INFO: Point: 55 (187.500, -500.000)]
[MSG:INFO: Point: 56 (375.000, -500.000)]
[MSG:INFO: Point: 57 (375.000, -375.000)]
[MSG:INFO: Point: 58 (375.000, -250.000)]
[MSG:INFO: Point: 59 (375.000, -125.000)]
[MSG:INFO: Point: 60 (375.000, 0.000)]
[MSG:INFO: Point: 61 (375.000, 125.000)]
[MSG:INFO: Point: 62 (375.000, 250.000)]
[MSG:INFO: Point: 63 (375.000, 375.000)]
[MSG:INFO: Point: 64 (375.000, 500.000)]
[MSG:INFO: Point: 65 (562.500, 500.000)]
[MSG:INFO: Point: 66 (562.500, 375.000)]
[MSG:INFO: Point: 67 (562.500, 250.000)]
[MSG:INFO: Point: 68 (562.500, 125.000)]
[MSG:INFO: Point: 69 (562.500, 0.000)]
[MSG:INFO: Point: 70 (562.500, -125.000)]
[MSG:INFO: Point: 71 (562.500, -250.000)]
[MSG:INFO: Point: 72 (562.500, -375.000)]
[MSG:INFO: Point: 73 (562.500, -500.000)]
[MSG:INFO: Point: 74 (750.000, -500.000)]
[MSG:INFO: Point: 75 (750.000, -375.000)]
[MSG:INFO: Point: 76 (750.000, -250.000)]
[MSG:INFO: Point: 77 (750.000, -125.000)]
[MSG:INFO: Point: 78 (750.000, 0.000)]
[MSG:INFO: Point: 79 (750.000, 125.000)]
[MSG:INFO: Point: 80 (750.000, 250.000)]
[MSG:INFO: Point: 81 (750.000, 375.000)]
[MSG:INFO: Point: 82 (750.000, 500.000)]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Measured waypoint 48]
[MSG:INFO: Measured waypoint 49]
[MSG:INFO: Measured waypoint 50]
[MSG:INFO: Measured waypoint 51]
[MSG:INFO: Measured waypoint 52]
[MSG:INFO: Measured waypoint 53]
[MSG:INFO: Measured waypoint 54]
[MSG:INFO: Measured waypoint 55]
[MSG:INFO: Measured waypoint 56]
[MSG:INFO: Measured waypoint 57]
[MSG:INFO: Measured waypoint 58]
[MSG:INFO: Measured waypoint 59]
[MSG:INFO: Measured waypoint 60]
[MSG:INFO: Measured waypoint 61]
[MSG:INFO: Measured waypoint 62]
[MSG:INFO: Measured waypoint 63]
[MSG:INFO: Measured waypoint 64]
[MSG:INFO: Measured waypoint 65]
[MSG:INFO: Measured waypoint 66]
[MSG:INFO: Measured waypoint 67]
[MSG:INFO: Measured waypoint 68]
[MSG:INFO: Measured waypoint 69]
[MSG:INFO: Measured waypoint 70]
[MSG:INFO: Measured waypoint 71]
[MSG:INFO: Measured waypoint 72]
[MSG:INFO: Measured waypoint 73]
[MSG:INFO: Measured waypoint 74]
[MSG:INFO: Measured waypoint 75]
[MSG:INFO: Measured waypoint 76]
[MSG:INFO: Measured waypoint 77]
[MSG:INFO: Measured waypoint 78]
[MSG:INFO: Measured waypoint 79]
[MSG:INFO: Measured waypoint 80]
[MSG:INFO: Measured waypoint 81]
[MSG:INFO: Measured waypoint 82]
CLBM:[{bl:2186.55, br:2190.75, tr:2227.18, tl:2227.63},{bl:1966.12, br:1968.68, tr:2527.40, tl:2521.83},{bl:1296.66, br:2674.37, tr:3120.85, tl:2054.06},{bl:1365.16, br:2709.12, tr:3060.32, tl:1950.31},{bl:1444.36, br:2749.70, tr:2996.77, tl:1849.15},{bl:1530.56, br:2795.13, tr:2937.15, tl:1750.93},{bl:1620.34, br:2844.54, tr:2881.75, tl:1656.43},{bl:1716.50, br:2900.09, tr:2830.77, tl:1566.14},{bl:1815.35, br:2958.13, tr:2784.47, tl:1480.98},{bl:1913.65, br:3021.32, tr:2743.10, tl:1401.71},{bl:2018.92, br:3088.11, tr:2706.88, tl:1329.54},{bl:2125.65, br:2945.14, tr:2527.04, tl:1482.43},{bl:2032.67, br:2874.33, tr:2564.78, tl:1546.14},{bl:1936.75, br:2807.29, tr:2609.49, tl:1617.67},{bl:1844.34, br:2744.29, tr:2656.69, tl:1695.82},{bl:1755.92, br:2685.64, tr:2709.86, tl:1781.02},{bl:1672.17, br:2631.63, tr:2770.86, tl:1867.62},{bl:1593.88, br:2582.56, tr:2831.02, tl:1957.48},{bl:1521.70, br:2538.69, tr:2897.49, tl:2053.16},{bl:1456.87, br:2500.39, tr:2966.22, tl:2148.73},{bl:1621.47, br:2321.53, tr:2822.81, tl:2267.69},{bl:1678.08, br:2356.60, tr:2748.09, tl:2184.47},{bl:1741.91, br:2403.86, tr:2677.17, tl:2094.59},{bl:1814.04, br:2455.37, tr:2610.31, tl:2008.50},{bl:1891.09, br:2511.96, tr:2547.86, tl:1926.70},{bl:1974.24, br:2573.28, tr:2489.93, tl:1849.68},{bl:2060.09, br:2639.65, tr:2437.18, tl:1778.17},{bl:2148.79, br:2709.04, tr:2389.88, tl:1712.75},{bl:2241.88, br:2782.29, tr:2348.15, tl:1654.21},{bl:2367.56, br:2649.32, tr:2170.95, tl:1816.65},{bl:2285.79, br:2570.37, tr:2208.46, tl:1869.77},{bl:2200.67, br:2495.18, tr:2266.36, tl:1930.09},{bl:2119.80, br:2424.11, tr:2322.26, tl:1994.66},{bl:2043.34, br:2357.51, tr:2381.60, tl:2067.07},{bl:1971.85, br:2295.79, tr:2448.54, tl:2142.70},{bl:1905.88, br:2239.40, tr:2516.75, tl:2224.22},{bl:1845.92, br:2188.62, tr:2594.33, tl:2307.37},{bl:1792.83, br:2144.08, tr:2669.34, tl:2391.53},{bl:1964.20, br:1968.56, tr:2536.93, tl:2526.48},{bl:2018.01, br:2008.96, tr:2453.51, tl:2454.04},{bl:2072.12, br:2064.49, tr:2373.79, tl:2374.31},{bl:2130.68, br:2124.18, tr:2298.10, tl:2298.74},{bl:2195.42, br:2190.45, tr:2226.91, tl:2227.57},{bl:2264.98, br:2262.14, tr:2160.55, tl:2161.28},{bl:2338.54, br:2337.33, tr:2099.56, tl:2100.36},{bl:2418.31, br:2417.51, tr:2044.41, tl:2045.26},{bl:2499.82, br:2497.23, tr:1995.67, tl:1996.59},{bl:2640.95, br:2375.98, tr:1822.52, tl:2164.52},{bl:2568.53, br:2287.59, tr:1871.43, tl:2211.45},{bl:2493.34, br:2202.77, tr:1932.12, tl:2261.05},{bl:2422.14, br:2121.89, tr:1998.62, tl:2316.36},{bl:2355.62, br:2045.54, tr:2068.68, tl:2377.61},{bl:2293.79, br:1974.08, tr:2145.77, tl:2444.45},{bl:2237.22, br:1908.26, tr:2227.53, tl:2513.81},{bl:2186.48, br:1848.34, tr:2309.78, tl:2590.16},{bl:2141.88, br:1795.46, tr:2393.80, tl:2664.20},{bl:2314.44, br:1625.38, tr:2277.09, tl:2813.94},{bl:2360.36, br:1676.87, tr:2183.83, tl:2748.27},{bl:2407.38, br:1742.38, tr:2093.83, tl:2677.39},{bl:2459.80, br:1812.34, tr:2007.61, tl:2610.56},{bl:2515.69, br:1890.25, tr:1925.66, tl:2548.15},{bl:2575.88, br:1971.81, tr:1848.58, tl:2490.36},{bl:2641.84, br:2057.28, tr:1776.84, tl:2437.68},{bl:2710.47, br:2146.32, tr:1711.33, tl:2390.38},{bl:2784.33, br:2237.43, tr:1652.67, tl:2348.84},{bl:2935.58, br:2133.73, tr:1487.00, tl:2518.49},{bl:2872.63, br:2034.86, tr:1549.75, tl:2558.48},{bl:2805.55, br:1939.06, tr:1620.42, tl:2601.85},{bl:2742.51, br:1846.67, tr:1698.90, tl:2650.84},{bl:2683.83, br:1758.42, tr:1781.14, tl:2704.33},{bl:2629.77, br:1674.74, tr:1867.99, tl:2763.67},{bl:2580.66, br:1596.53, tr:1959.66, tl:2825.88},{bl:2536.76, br:1524.58, tr:2054.30, tl:2891.92},{bl:2498.53, br:1459.79, tr:2150.30, tl:2961.11},{bl:2672.00, br:1300.15, tr:2053.09, tl:3115.71},{bl:2710.68, br:1365.48, tr:1949.20, tl:3060.30},{bl:2751.88, br:1444.40, tr:1847.90, tl:2996.80},{bl:2797.49, br:1530.05, tr:1749.57, tl:2937.24},{bl:2847.67, br:1620.02, tr:1654.85, tl:2881.88},{bl:2903.65, br:1714.15, tr:1564.39, tl:2830.97},{bl:2961.72, br:1811.59, tr:1478.95, tl:2784.73},{bl:3023.56, br:1912.79, tr:1399.53, tl:2743.41},{bl:3090.11, br:2015.50, tr:1327.17, tl:2707.25},]
Computing… This may take several minutesFitness: 0.8096013 in 100
Fitness: 0.8104624 in 200
Fitness: 0.8105433 in 300
Fitness: 0.8105433 in 400
Fitness: 0.8105433 in 500
Calibration values:
Fitness: 0.8105432877127149
Maslow_tlX: -23.7
Maslow_tlY: 2436.8
Maslow_trX: 3686.8
Maslow_trY: 2438.6
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3662.2
Maslow_brY: 0.0
CenterPoint after calibration:
LOG
Serial Messages
[MSG:INFO: Top Right pulled tight with offset -1183.127]
[MSG:INFO: Bottom Right pulled tight with offset -1861.766]
[MSG:INFO: Top Left pulled tight with offset -2575.039]
[MSG:INFO: Bottom Left pulled tight with offset -2944.940]
[MSG:INFO: Center point deviation: TL: -0.017 TR: 0.135 BL: -5.114 BR: -7.150]
[MSG:INFO: Center point deviation within 15.000mm, your coordinate system is accurate]
Will dry to dry cut the maslow logo after the baby is sleeping for his nap ![]()
Dry cut of the maslow logo is SUCESSFUL. Obviously don’t know what it looks like but it did finish.
Serial Messages
[MSG:INFO: Bottom Right pulled tight with offset -2037.902]
[MSG:INFO: Top Left pulled tight with offset -2078.731]
[MSG:INFO: Bottom Left pulled tight with offset -2037.591]
[MSG:INFO: Top Right pulled tight with offset -2074.501]
[MSG:INFO: Center point deviation: TL: 0.147 TR: 0.127 BL: -5.133 BR: -9.483]
[G54:0.000,0.000,0.000]
[G54:0.000,-100.000,0.000]
[GC:G0 G54 G17 G20 G90 G94 M5 M9 T0 F0 S0]
[MSG:INFO: Tool No: 0]
[GC:G0 G54 G17 G20 G90 G94 M3 M9 T0 F0 S0]
[GC:G1 G54 G17 G20 G90 G94 M3 M9 T0 F762 S0]
[GC:G3 G54 G17 G20 G90 G94 M3 M9 T0 F762 S0]
[GC:G2 G54 G17 G20 G90 G94 M3 M9 T0 F762 S0]
[GC:G0 G54 G17 G20 G90 G94 M3 M9 T0 F762 S0]
[GC:G0 G54 G17 G20 G90 G94 M5 M9 T0 F762 S0]
[GC:G1 G54 G17 G20 G90 G94 M30 M5 M9 T0 F762 S0]
[MSG:INFO: Program End]
[GC:G1 G54 G17 G20 G90 G94 M5 M9 T0 F762 S0]
[MSG: /sd/Maslow Logo.nc file job succeeded]
