Hi, I’m trying to set up the machine for the first time, but I can’t find any instructions for the latest software version. Even the Wi-Fi setup guide seems to be outdated.
Does anyone know the correct setup steps? I’ve tried both methods I found, but neither one works.
Also, the calibration process seems to never finish. Once the belts are tensioned, the machine doesn’t move at all. Has anyone else experienced this or found a solution?
also here are my current settings
bar
July 13, 2026, 5:09pm
2
Yes!
These are the instructions you are looking for:
Introduction
How to set up your Maslow CNC for the first time
Connecting your Maslow to WiFi and LAN networks
The step by step guide to finding anchors on a Maslow
Troubleshooting your Maslow connection and anchor issues
Essential tips for preparing your Maslow to cut
This instruction will be out of date by the time it is released but lets just go with it.
So, you have assembled your Maslow and the frame is built. Your next step is to get it ready to cut.
Just a few things to make it easier…
Where do you think that the right place for those instructions to live is? Where are the outdated ones that you are reading located?
We were just discussing how to make this more clear
ian_ab
July 13, 2026, 9:58pm
3
Welcome
That looks like an old version of software. When you click on test what versions come up? The new version looks like
You may need to load software via USB if the version does not start with a v1.0 or higher.
The latest version is here
Releases · MaslowCNC/Maslow_4
unzip either https://github.com/MaslowCNC/Maslow_4/releases/download/v1.23.0/fluidnc-maslow4-1.23.0-posix.zip for Mac or
https://github.com/MaslowCNC/Maslow_4/releases/download/v1.23.0/fluidnc-maslow4-1.23.0-win64.zip for windows
This video will help if you need to load via USB. Substitute V1.23 where video says V1.10
This is a once only procedure.
