Maslow 4 with upgrade - cannot calibrate
I have been working towards my first cut. I had the 4.0 for over a year, but never had the room or time to focus on it. I purchased the upgrade kit and built my first Maslow with the 4.1 instructions. I, however, am stuck. I think it is a software version issue, but I cannot calibrate.
In my version I have “find anchor locations”, not the calibrate button I see in the guide. I did update the firmware to 1.13 via USB, as I think it started at .8…, I also downloaded and replaced the index and maslow file from github. I have rebooted after that. Maybe the wording doesn’t matter?
I was able to retract, extend, and mount the Maslow to my stand.
Any suggestions are welcome.
Thanks and happy cutting.
in the guide.
Yes, the guide has not been updated, “find anchor locations” is what calibrate
did, but the word “calibrate” implies more.
what happens when you try “Find Anchor Locations”?
What do you get when you press Test?
A copy of your serial log is helpful to see what is going on
I decided to wipe and start over. After getting it back online, I was able to hang the run the find anchors. Thanks for the advice. I am not sure what hung it up last pass, but it is easy enough to reload.
Thanks for the advice. I now have new questions, but I will look them up in the other post.
