I’ve looked all over the forums but I can’t find this issue. I literally just got my Maslow together so I have no reference here. I’m using Linux mint and both firmware and GC of 1.12.
When I go to do the calibration process I cannot manually move the motors. I’ve tried rebooting, reloading firmware, trying a nother download of GC. When I do a test the motors move the proper way on the proper sides, just in calibration I can’t do it manually. I’ve got it centered but I wasn’t able to get the sprockets exactly at a noon position. I’m putting the z access together tonight and I’m hoping to get to cut the permanent sled.
Any ideas on what I’m doing wrong? Only the motor calibration doesn’t work. Looks like rest of the calibration process works and testing.
No. I’m pressing the ccw and cw button on the first page of the calibration. Other steps the motors turn and when using the testing button. The first page of the calibration I cannot use any of the .1, 1, or 5 degree rotation buttons at all.
That’s strange. Nothing I can compare to. On Mint you are running form a terminal, right?
Any observations there?
The log.txt from the GC folder would be of interest. Also perhaps the start up of GC in the terminal.
I remember someone else reporting the same issue, but it disappeared before we were able to pin it down. It’s really strange that you can move the motors further along in the calibration process but they don’t move in the “adjust to 12” step because the same command is used in both cases.
Do you hear a noise from the motors powering up, but they don’t move or is there no noise?
What shows up in the black terminal window that opens with Ground Control when the issue is happening?
I think I remember a post mentioning that repetitively clicking before waiting for the noise to stop could cause an issue but can’t find the post.
Since you have not had a running configuration I would try FW/GC 1.13 and if the error is still there try 1.11. Both with a ‘clean’ state, meaning wiping eeprom and rename or delete groundcontrol.ini.
When unzipping the firmware I always use a new folder, found issues when I used the same folder just overwriting with new releases.
Did you install pip on your mint?
OH wow! I didn’t know there was a 1.13. I will give that a go. If that doesn’t work I will downgrade.
I’m trying to keep the versions in different folders so there is no collusion.
I don’t have an idea where to search so comparing our linux could rule things out.
‘pip list’ in a terminal gives the versions of the python modules.
I’m interested in the pyserial version (mine pyserial (3.3))
Ok so it sounds to me like this is a software thing for sure that’s why I asked about the noise. The fact that the motors don’t want to move for the little jogs but will move for the larger extends is interesting because the command used is identical for the very small moves to orient the sprockets and the larger moves to extend the chains etc.
I think the first thing we should test is to establish a threshold for how large of a motion we need to command before you can see the sprocket move.
Copying and pasting these lines into one of the macro functions will make a button which will rotate the left motor by however much we put in there:
G91
B09 L-0.176388888889
G90
The G91 switches to relative mode, the B09 LXXX says how far to move in that direction and the G90 switches us back to absolute coordinates. So those commands will tell the left motor to move 0.17 inches in the negative direction
If we slowly increase that number we should be able to see where the machine starts to move. My theory is that we’re somehow in MM mode when we want to be in inches so the motors are moving but 0.17mm is too small to see
[quote=“bar, post:13, topic:3860”]
G91 B09 L-0.176388888889 G90[/quote] @bar perfect! I had this issue still on 1.12 and 1.13, but those commands help. With you suggesting upping the numbers when I get to .8 it will start moving maybe .5 degrees. I can at least get the motors on a 12 O’clock position. Would I assume if I did Z would that work for getting the z motors moving manually?
I’m still pretty stumped as to why the command would work differently on different machines…is there anything different about your hardware @cyberpatriot?
It’s a pretty old hp laptop, but I’m running the latest version of mint. I would say it’s upwards of 8 years old. Core 2 Duo. But I’m certain it still more power than a raspberry pi 2.
If there’s something off in the chain pitch and number of teeth on sprocket, the calculations can be off on the amount to turn. Can you post those values from the settings?
That’s a good suggestion @madgrizzle those settings would cause this type of behavior…but why would the machine work normally everywhere except this one calibration step?
Would you guys be willing to try a special firmware which prints more information?
It will print if the machine is in relative or absolute mode and what units are being used. At least for me the buttons are OK in either mm or Inches mode. We want the motor to be running this command in relative mode so it moves a small amount relative to where it is not absolute mode which would be moving the motor to the same location over and over
Hey!
I have the same problem. Both in calibration and in automatic chain length I cannot jog the motors to 12’o clock.
I have been going a bit back and forth between firmware and GC versions. It appears to have happened in the 1.12 firmware version because i works with firmware version 1.11 and GC version 1.13.
I will try the debug firmware in the weekend to see if it can print anything useful.
By the way @Bar and Hannah great project I have been having a lot fun building the machine so far.
