Can someone help me out via zoom, I can pay
I’m currently strugeling with importing files into fluid
I have tried files exported via fusion 360, desk proto, and kiri moto. and am unable to upload them to fluid. help!
Cheers
Fusion 360 could create the gcode file for you. You have to use the manufacture module and then a generic grbl post processor.
Dano
Have you generated the tool path in Fusion?
I have used fusion to generate gcode for commercial metal CNC machines in previous career. I have not created one for Maslow yet. Morely because I haven’t generated any projects for Maslow yet.
Dano
I used the “Maslow” post processor
yes, exported an .nc file. has anyone gotten the nc files to work?
have you found any cam software that makes filed you are able to import into fluid?
You can open nc files in fluid. They look just like what’s fusion producing. I’m still dialing in the settings. Calibration height, retract height and few other settings in fusion are still a bit of a puzzle and will require some experimenting.
Is it not work for you?
I’m happy to spend the time working out the macros on my own
however I’m currently stone walled by the fact i can’t upload anything to fluid.
if there is anyone who can walk me through step by step how they upload files then i can get started working out the details in the settings myself. for someone who uses the maslow often this should be super quick. probably just need to click the right box somewhere along the way
worked it out, I was using the captive portal. needed to open it in the browser to get it to upload files
