I’m having trouble uploading files to fluid
the gcode files and nc files are greyed out when trying to upload
what software are you using to generate them?
fusion 360, kiri moto and desk proto
What is the file extension?
It’s expecting something like .nc or .gcode
.nc files mostly. I did get a gcode file to work once, but i forgot how to make .gcode files
You can just change the .nc on the end of file to .gcode it’s all the same inside…but they should all work.
What firmware version are you using?
I like that idea of changing the .nc to .gcode.
it didnt help me out
probably some box that needs to be ticked or something
version 1.07
The preferences setting for which files are allowed is under “preferences” here
Does everything look right in there?
looks good to me.
coult there be an issue with the captive portal?
the upload gcode button doesn’t work on my mac
(I use my ipad instead)
we’ve seen many things not work in the captive portal browser, try closing that
browser window and opening a new browser.
BOOM that was it, Cheers dlang.
