I am having emergency stop trouble, caused by Position errors, caused by Encoder read failures. I noticed in the log file that these errors occur right after Unsupported GCode command:
[MSG:INFO: FluidNC v0.74 (Maslow-Main-dddcbc15-dirty)]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Config messages ran]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Set to comply]
Index.html Version: 0.75
[MSG:INFO: Firmware Version: 0.75]
[MSG:INFO: Magnet detected on Top Left]
[MSG:INFO: Magnet detected on Top Right]
[MSG:INFO: Magnet detected on Bottom Left]
[MSG:INFO: Magnet detected on Bottom Right]
[MSG:INFO: Top Left pulled tight with offset -1767.814]
[MSG:INFO: Bottom Left pulled tight with offset -1802.513]
[MSG:INFO: Top Right pulled tight with offset -2010.160]
[MSG:INFO: Bottom Right pulled tight with offset -2036.195]
[MSG:INFO: Center point deviation: TL: 0.236 TR: 0.304 BL: -4.113 BR: -3.378]
[MSG:INFO: Center point deviation within 15.000mm, your coordinate system is accurate]
[MSG:ERR: 20 (Unsupported GCode command) in /sd/zaagtafeltest.nc at line 66]
[MSG:ERR: 20 (Unsupported GCode command) in /sd/zaagtafeltest.nc at line 68]
[MSG:ERR: 20 (Unsupported GCode command) in /sd/zaagtafeltest.nc at line 70]
[MSG:WARN: Encoder read failure on Bottom Left]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 5 times in the last second]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 1 times in the last second]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 27.285mm Counter: 1]
[MSG:WARN: Previous error was 27.285mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 27.278mm Counter: 2]
[MSG:WARN: Previous error was 27.278mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 27.270mm Counter: 3]
[MSG:WARN: Previous error was 27.270mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 27.263mm Counter: 4]
[MSG:WARN: Previous error was 27.263mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 27.255mm Counter: 5]
[MSG:WARN: Previous error was 27.255mm]
[MSG:WARN: Encoder read failure on Top Left]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 1 times in the last second]
[MSG:INFO: Reset during file job at line: 139]
[MSG:ERR: Emergency stop. Update function not being called enough.1002ms since last call]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.309mm Counter: 1]
[MSG:WARN: Previous error was 20.309mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.301mm Counter: 2]
[MSG:WARN: Previous error was 20.301mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.293mm Counter: 3]
[MSG:WARN: Previous error was 20.293mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.276mm Counter: 4]
[MSG:WARN: Previous error was 20.276mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.268mm Counter: 5]
[MSG:WARN: Previous error was 20.268mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -25.439mm Counter: 1]
[MSG:WARN: Previous error was -25.439mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -25.446mm Counter: 2]
[MSG:WARN: Previous error was -25.446mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -25.454mm Counter: 3]
[MSG:WARN: Previous error was -25.454mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -25.462mm Counter: 4]
[MSG:WARN: Previous error was -25.462mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -25.469mm Counter: 5]
[MSG:WARN: Previous error was -25.469mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -25.477mm Counter: 6]
[MSG:WARN: Previous error was -25.477mm]
[MSG:ERR: Position error > 15mm while running. E-Stop triggered.]
The offending GCodes are G98 and G81 in this piece of code:
(Begin Drilling)
G0 Z5.000
G90
G98
G0 X33.482 Y76.704
G81 X33.482 Y76.704 Z-2.000 R3.000
G0 X86.170 Y76.704
G81 X86.170 Y76.704 Z-2.000 R3.000
G80
G0 Z3.000
G0 Z5.000
(Finish operation: Drilling)
Could the unsupported codes have anything to do with the emergency stop or is this just a coincidence?
