Multiple folks have reported getting the 15mm error while moving message while cutting. I’ve been trying to dig into what could be going on, but I haven’t been able to make it happen on my machine.
Since it wasn’t happening for me, @Anna and I decided to switch up the environment and see if we could make it happen somewhere else.
Anna assembled a fresh Maslow4 and we went down to our local makerspace.
Overall it was a great experience and we learned lots of things that we could improve on (better calibration if the anchors aren’t a square, better gcode preview ideas, make it less easy to click the “define home” button accidentally, etc). It’s really interesting how setting up in a new environment changes things.
But the biggest win was that we were able to get the 15mm position error to happen while running.
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.131mm Counter: 1]
[MSG:WARN: Previous error was 15.131mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.179mm Counter: 2]
[MSG:WARN: Previous error was 15.179mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.216mm Counter: 3]
[MSG:WARN: Previous error was 15.216mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.254mm Counter: 4]
[MSG:WARN: Previous error was 15.254mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.634mm Counter: 5]
[MSG:WARN: Previous error was 15.634mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.691mm Counter: 6]
[MSG:WARN: Previous error was 15.691mm]
Because this machine was brand new it didn’t have a dust collection outlet and we didn’t bring our dust collector with us. As we were cutting we used this vacuum to suck up the dust around the machine occasionally:
Twice we were able to make the error happen while sucking up the dust near the machine. It didn’t happen every time we used the vacuum, but we were able to get it to happen twice.
It seems like the issue is generally related to EMF. My hunch is that it was an issue with static build up on the dust collector hose because in both cases where we had it happen it was when the vacuum hose touched the machine or was near the encoder cables. Static in dust collector hoses is also a known issue for this kind of thing:
It’s also possible that the issue is some sort of noise on the electrical system. The maker space wiring isn’t the greatest and the lights dim pretty dramatically when the shop vac comes on…that being said the issue didn’t seem to come from the vacuum turning on as much as when the vacuum hose touched (or was very close to) the machine.
We will keep investigating next week, but I figured I would throw that idea out here in the meantime.
