Can you stop without reseting?
I’m running my M4, but the bit isn’t diving low enough into the wood. Is there a way to stop the M4 with out having to pull the unit off the frame and do a full retract/extent? I just want to upload the new GCode file and try again
I was able to do this yesterday with “pause”, then “stop” then refresh the browser, then load gcode again, then I don’t remember if I had to clear an alarm… I’m intending to see if I can figure out a better way and make the UI better for this.
When you do have to reset, if you have a vertical frame, this makes it much less annoying.
I haven’t measured this, just grabbed some scrap and drilled a single hole for the bolt-hinge, but am planning something thinner. Still, concept is sound as is.
