I have been trying to get my M4.1 running for a few days now. I was able to get one test cut done and then it just wouldn’t find the anchors again. I checked the machine out to see what could be wrong and found broken parts. See the attached. The support between the lower and upper clamp broke and the lower clamp wedge broke. I don’t like the plastic that this is made out of. Its very brittle and cracks. I can print parts much stronger on my 3D resin printer. I just need the files. So for now i need some replacement parts or the STL files so i can do it myself. I use ultra strong resin and it will be better than the OG plastic molded parts. Once i have the new parts done ill go back to set it up and see if i can get this working. Need to make some money with this thing.
I think files are up on GitHub somewhere but also check.
Dano
Source — Maslow has all the files but @Dano is right that a lot of parts have been redesigned for 3D printing and are in that thread
Here is a good support and internal spacer replacement for the posts. Requires a longer bolt. If you are printing people also like the turtle clamp. Turtle Clamp (non-split clamp design)?
Im really disappointed with the plastic used to make this product. When we disassembled the machine just about every part was damaged or borken. Im reprinting all the parts in ABS resin on my 3D printer. If i cant get this to work its going to be a huge let down as ill have many hours into this. I really want this to work but it seams like a toy instead of of a machine.
