Piezas dañadas con grietas recibidas
hace un mes mas o menos recibi mi maslow con mucha ilusion hace una semana comence a armarlo pero al ir viendo con detalle encontre fisuras en la base del trineo y en los refuerzos que van en las barillas del eje z ojala no me den problemas al llegar a casa compartire fotografias anoche las encontre y no pude tomarlas por la falta de lus natural para que se aprecien bien no se que problema me podran traer pero les comento para ver que solucion puede darme gracias
Translated
​About a month ago, more or less, I received my Maslow with great excitement. A week ago I started assembling it, but as I was looking at it in detail, I found cracks in the base of the sled and in the reinforcements that go on the Z-axis rods. Hopefully, they won’t cause me problems. When I get home, I will share photos; I found them last night and couldn’t take [the photos] because of the lack of natural light to see them well. I don’t know what problems they might cause me, but I’m telling you all to see what solution you can give me. Thanks.
I have replaced the 4 support legs and the top and bottom router clamps with 3D printed versions, the STL’s are available here on the forums.
The printed legs on here are a bit shorter than stock, but a much more robust design.
The Turtle Clamp appears to be a major improvement from the stock clamps. This clamp setup will require a few pieces of aftermarket hardware, but its worth it.
si ? y donde puedo encontrarlas para evaluar si las puedo enviar a imprimir solo que aca en mi pais las impresiones 3d son muy costosas
Scroll up and you will find the turtle clamp and support posts.
