Turtle Clamp (non-split clamp design)
Why turtle clamp? Fresh off the printer, the cutout looks like a turtle to me:
Files here:
Intro
Stiffness of the clamps is something that I’ve been keen on improving for a while. I touched on it a bit as part of my I linear rails-ed my Maslow build. 20mm thick clamps seemed like an obvious place to start and gave me a significant improvement, but there was a lot more I wanted to do.
This is what I came up with:
There were a few points I wanted to address:
  • No split in the clamp.
  • 20mm but minimising Z-travel loss.
  • Full compatibility with original Maslow.
This is like the main point of it. The split in the clamp has always bothered me for two reasons - as a source of flex, and a source of imprecision. With the 20mm design I came up with for the linear rail build I did my best to minimise flex with a big zig-zag double bolt, and that was ok, but still allowed more flex than I was happy with.
For the linear rail the bigger issue is it messes with the geometry. Tightening and loosening the clamp pulls everything out of square, even if it’s by a very small amount. For anything to do with linear rails that’s a bit of a PITA.
I could run through the many wild and whacky clamping methods I tried, most of which were good at applying force, but only to the point they ripped themselves apart, but it’s not that interesting. The four-clamp, triangle-edged design gives me the clamping force I want, centred, with easy access for adding / removing the router with the Maslow fully built. It even keeps compatibility with the button pusher.
The 20mm thickness combined with no split is what makes it very stiff, but another downside of the design I used in the linear rail build is I lost a chunk of Z-travel. That isn’t a massive deal for me given the bits I personally use, but I wanted to go back and minimise it if possible.
The main focus was the bottom clamp to get the router as low as possible at Z-stop.
you can see that there are cutouts on the Z-stepper arms and little cutouts on the rail arms, for the motors and vacuum plate bolts respectively.
It lets it sit flush to the vaccuum plate:
And gets me to the point of 7-8mm off flat for the bottom of the collet at Z-stop:
I can’t really show this without teasing the next thing I’m currently in the final stages of refining, but another motivation was wanting it to be standalone (ie a user can just replace the original clamps), but also to work with a linear-bearing-not-linear-rail variation of my linear rail build that minimises extra weight / new parts:
While it looks quite different from the original Maslow 4.1, the important bit to note is it’s using the original linear bearings / plastic risers so the clamps can be used as the only mod to a stock Malsow if wanted.
Build details
Printing the main clamp with 5 layer top and bottom and 5 wall loops, along with 40% adaptive cubic infill gives high stiffness. It can be dialled back to 3 wall loops and 30% adaptive cubic infill (still 5 wall loops) and that saves about 20g a clamp and barely impacts stiffness. The inserts I printed at 100% infill.
It uses m3 slip-nuts / hammerhead nuts / t-nuts - the 2020 profile nuts that turn and grip, combined with 10mm plate washers and 14/16mm cap head bolts (all of which I believe should be widely available everywhere):
Notes:
  • It expects 2mm worth of 10mm plate washers, I just used 2 * 1mm adhesive ones.
  • Although I say 14mm or 16mm bolts, it should work with anything up to 20mm without fouling on the rotating arms, even if the bolt heads stick out slightly.
  • You need to use longer bolts to hold on the posts - I use 25mm with locknuts as it’s a size I use on other projects.
  • Everything should be flush when the router is inserted, it’s reasonably tight tolerances so that each insert only needs to slide about half a mm to clamp.
  • There is no need to crank it down until you damage it, it holds with a lot of force just from being snug.
Very cool. Thank you for sharing. Will be interested in trying it. Nice write up.
Nice bit of lateral thinking, would appreciate it if you could put the step or stl files here or https://forums.maslowcnc.com/t/maslow-4-3d-printed-parts-thread
I like the title Turtle Clamp
This is super awesome! The clamping mechanism was something that I went through a lot of iteration on how to make it work so I appreciate a good design!
Thanks - I’m trying doing it as a PR to the new place we are gathering things, I’ll post a link in here and that usual 3D printed thread once it’s in though :slight_smile:
It’s an interesting problem to try and solve for sure - having to be both structural and adjustable is tricky. It’s interesting the possibilities additive manufacturing gives you over molded components too - not quite sure how i’d get it to work in a mass production design!
Now uploaded here:
Did a little update with some QOL improvements:
1.1 Update
  • The depth of the bolt area has been standardised so they all use 10mm of bolt-thread.
    • This means 15+mm bolts will work if re-using the standard posts, 25mm with some other of my designs.
    • Which in turn means a conversion of only the clamps just needs 28 x 16mm cap head screws.
  • Added variants:
    • NoBaseCutoutClamp - doesn’t have the cutouts for getting the router as flat to the base as possible. Can still be used as a Top or Base clamp.
    • Top-NoBaseCutoutNoZCutoutClamp - has no cutouts that aren’t needed for a Top Clamp - can only be used for the top.
    • Base-HexReinforcedClamp - Has some extra re-inforcement that only works for a Base Clamp (the motors would foul if it was a Top).
    • Base-SolidReinforcedClamp - As HexReinforced, but solid.
@ian_ab pointed out that rotating the clamps and button pusher hole could help with the 240V dewalt vertical power lead problem (I think combined with a different control board mount to keep the board axis aligned).
@ian_ab - I think this should be right (and it can be mirrored if I got the direction wrong):
Offset Turtle Clamp 1.2 Anticlockwise.stl (1013.5 KB)
It’s untested, but given I use the 240V myself and just hadn’t thought of that :man_facepalming: I’ll print it and try it in the next day or two, and I have a few tweaks I was going to roll into a 1.2 version soon that I’ll include it as a variant in.
