Clamp Posts decided enough was enough
For the new year some of the M4’s clamp posts decided enough was enough:
No screw holes for me then.
So I 3D printed two of them as a single part, seems much better:
What do you think about making the STL file available? Thanks.
FullInnerPost.stp (643.8 KB)
Try this - although it is a step file
Aloha,
  • What material did you print these in?
  • How was the part oriented on the build plate?
  • What settings (infill, walls, layer height, supports, etc) worked
  • How do they seem to be holding up?
Mahalo,
  • Material - PETG
  • Orientation - Vertical, I figured this would be the least amount of support material needed
  • Settings - infill was adaptive cubic at 20% I think, but these things are fairly thin walled, so they’re mostly solid anyway, walls were 5 (again if I remember correctly), supports definitely (I did regular, but I think tree might be better), etc I did consider using a brim, but deliberately decided against it in the end.
  • Working? Seems to be, but not really used in anger yet
Aloha,
Finally circled back to this and printed one (to make sure my settings were okay; I’ll print three more).
I have a Prusa XL with 5 tool-heads (extruders). I printed the upright out of blue PETG, and used PLA for the support interface (where the support meets the model. The supports are PETG until a couple of millimeters before the overhang.
My first attempt, I had some bed adhesion issues, but I sorted that out and the second time got this. It’s gorgeous, and because PETG and PLA don’t stick to one another, the supports basically just fell off. Had to use a dental tool to deal with the nut cavities, but it took less than a minute because again, the PLA didn’t stick to the PETG; the only reason there was any PLA left was friction with the walls.
My Hero!
I noticed some of mine were cracking a while ago. Just got around to trying to install my 4.1 upgrade… which involved removing some of those nuts and bolts and more bits just flaked away. I was contemplating if I shoud design my own part or order the replacement parts. I knew I couldn’t be alone. And THIS IS PERFECT! I’ll be printing tonight when I get home from work.
