AFAICT from docs, Holey is the “best” insofar as that it does a better job with calibration than stock.
For some reason, I’m getting timeout/errors when I try to upgrade from sock firmware within WebControl. I am guessing I should manually upgrade from Android IDE (?) If so, should I use the Holey firmware from the WebControl repo, or is there a better option?
Also, w.r.t. upgrades, I take it that flashing firmware has no effect on any system settings or calibration (which is all stored in Groud/Web Control)? So post-upgrade, it’ll work as normal but I can then run a “holey test cut?”
