Could this be adapted to create a frame?
Do you think this could easily be modified to be a roll around frame for the maslow4? I’m thinking of creating some bolt on arms with 3/8 rods sticking out for the maslow to clip into. Thx
That stand supports very little surface area of the ply and looks pretty light weight. I don’t think it would be worth the effort or time to try to modify it. You would be able to make something more sturdy and better quality for the price you would spend on buying that and extensively modifying it.
Seconding Tim’s comment.
You could build something much nicer (metal is not always nicer) for less using 2x4s, 6" casters, and 1/2" bolts (to make the hinge and to act as pins for holding it vertical or horizontal).
The other thing is that you’d have to have two YAML files, one for horizontal and one for vertical, so that the machine is accurate in each arrangement, if you wanted to get anything out of being able to rotate it.
