Just what it says. The calibration process is 99% finished. The Center Point is about 8 inches low and about an inch to the left of the actual work area center. Rather than go through the calibration process again (it’s about my 6th time now), I’d like to manually move the router to the measured center of the work area and call that the new center (0,0,0). Is there a button that will do this? I can set that as the home point but when I run the chain sag calibration it returns to the low “center” point. I’d like to do this so I can finish the chain sag portion of the config and get cutting. Side note: I tried a test cut without finishing the chain sag and my circle came out as an oval.
Any help would be appreciated. Thank you!
