Did I ruin my sled?
I didn’t read ahead in the assembly manual and installed my linear rods with the linear rod clamps already installed. I didn’t realize it was a separate part as they came pre-installed on the sled. So I tapped my rods in. When I got to the next step I realized.
Did I screw up the tension of the linear rod clamps and will this cause issues for me down the road?
Thanks!
Nope, you should be totally fine :grinning:
If you do run into any issues let us know and we can send you whatever parts you need, but I’m 90% sure that if nothing broke then it should be OK.
I did the same and it’s totally fine, no problem.
Me too! After inspecting things I saw no damage, and assume all will be fine. Might be worth a wording change in the assembly manual if you have these already placed on the sleds now @bar ?
Good call, I’ll fix that right now!
