The assembly says there will be a small gap, this seems to be a large gap. I made sure the linear rod is pushed all the way into the support base.
What options do I have?
- Try to grind off a few mm on the grinding wheel?
- Try to Dremel or cut off a few mm with a band saw?
- Shim the linear rod support off the sled with a washer or two?
Am I missing anything?
It was too long and not cut well from the factory like this.
I tried to use a band saw but the metal seems very hard.
A bench grinder took a few MM off pretty quick. It still fits tight but no plastic will crack now from tightening it down.
So it’s all together.
Yes I think you did the right thing, I had to do the same, it also distorts the sled when everything is clamped down and it is too long.
I believe this issue was addressed with the Maslow 4.1 and those rods are now CNC lathe cut instead of the old, less accurate, process.
