I received the lumber for making my frame. When i saw video on vertical calibration. I began to question what would happen to calibration if the frame was on an incline. So one belt wad supporting more weight than the other. Kind of like standing on 2 weight scales. It is difficult to equal weight on both scales.
I would like to know your opinion, i need to get started on frame soon.
What i sm wondering is in vertical mode is one side is at a different altitude due to slope of the ground. How much will that affect the calibration. I.E. do i need to put a level on the frame and shim to level.
That abgle will depend on how much friction between surface and sled. Some surfaces might be able to use vertical at 15 deg from horizontal. High friction surfaces might need the higher angle like 45 deg. I am beleiving horizontal would give better valibration than vertical on uneven ground. Our mobile home park slopes probably 10ft from entrace to far side. The orher angle has a slope but is less. Using inside is not possible. Deck is levem but maximum size would be about 4ft by 4ft. As deck is 10x10 but one corner has a 45 deg angle due to clearance from road. So one leg would be considerably shorter.
