It seems that ian_ab’s code worked for my maslow. I was able to get through calibration and into ready to cut mode. Amazing! Thanks Ian_ab! Now on to installing the bit and to cutting.
Maslow-serial (6).log (167.7 KB)
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Requesting state change from Finding Anchor to Find Anchors Computing]
[MSG:INFO: Succeeded]
CLBM:[{bl:1355.84, br:1348.35, tr:1415.59, tl:1399.17},{bl:1507.07, br:1197.41, tr:1275.03, tl:1547.86},{bl:1591.78, br:1319.05, tr:1181.57, tl:1456.46},{bl:1435.86, br:1426.62, tr:1340.63, tl:1325.18},{bl:1285.91, br:1558.11, tr:1500.05, tl:1186.06},{bl:1176.57, br:1462.04, tr:1595.84, tl:1313.00},{bl:1324.84, br:1379.25, tr:1446.40, tl:1359.80},{bl:1332.45, br:1323.56, tr:1443.89, tl:1425.77},{bl:1194.58, br:1460.75, tr:1574.74, tl:1304.77},{bl:1244.00, br:1511.06, tr:1525.07, tl:1229.37},{bl:1315.15, br:1569.86, tr:1477.54, tl:1170.31},{bl:1442.57, br:1445.64, tr:1338.22, tl:1305.77},{bl:1575.08, br:1315.99, tr:1195.73, tl:1450.05},{bl:1523.95, br:1240.71, tr:1244.45, tl:1500.23},{bl:1476.15, br:1181.56, tr:1313.32, tl:1559.31},]
Computing… This may take several minutesInitial guess fitness: 0.4493199
Frame dimensions: 2524.1mm x 1082.1mm (aspect ratio: 2.33:1)
Initial fitness >= 0.1 and frame is not square, skipping rectangular optimization and using initial guess directly.
Fitness: 0.5882481 in 100
Fitness: 0.5930257 in 200
Fitness: 0.5930257 in 300
Fitness: 0.5930257 in 400
Fitness: 0.5930257 in 500
Fitness: 0.5930257 in 600
Fitness: 0.5930257 in 700
Fitness: 0.5930257 in 800
Fitness: 0.5930257 in 900
Fitness: 0.5930257 in 1000
Fitness: 0.5930257 in 1100
Find Anchor Values:
Fitness: 0.5930257
Maslow_tlX: 20.9
Maslow_tlY: 1079.3
Maslow_trX: 2542.5
Maslow_trY: 1086.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 2532.3
Maslow_brY: 0.0
A command to save these values has been successfully sent for you. Please check for any error messages.
Find Anchors
[MSG:INFO: Requesting state change from Find Anchors Computing to Finding Anchor]
[MSG:INFO: Machine Position found as X: 154.380 Y: -143.905]
[MSG:INFO: Setting motor positions from hardware readings:]
[MSG:INFO: TL: 1410.925 TR: 1162.331 BL: 1323.985 BR: 1032.908]
[G92:0.000,0.000,-7.000,0.000,0.000]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
CLBM:[{bl:1355.84, br:1348.35, tr:1415.59, tl:1399.17},{bl:1507.07, br:1197.41, tr:1275.03, tl:1547.86},{bl:1591.78, br:1319.05, tr:1181.57, tl:1456.46},{bl:1435.86, br:1426.62, tr:1340.63, tl:1325.18},{bl:1285.91, br:1558.11, tr:1500.05, tl:1186.06},{bl:1176.57, br:1462.04, tr:1595.84, tl:1313.00},{bl:1324.84, br:1379.25, tr:1446.40, tl:1359.80},{bl:1332.45, br:1323.56, tr:1443.89, tl:1425.77},{bl:1194.58, br:1460.75, tr:1574.74, tl:1304.77},{bl:1244.00, br:1511.06, tr:1525.07, tl:1229.37},{bl:1315.15, br:1569.86, tr:1477.54, tl:1170.31},{bl:1442.57, br:1445.64, tr:1338.22, tl:1305.77},{bl:1575.08, br:1315.99, tr:1195.73, tl:1450.05},{bl:1523.95, br:1240.71, tr:1244.45, tl:1500.23},{bl:1476.15, br:1181.56, tr:1313.32, tl:1559.31},{bl:1335.42, br:1317.82, tr:1441.10, tl:1430.67},{bl:1378.77, br:1372.63, tr:1387.01, tl:1361.75},]
Computing… This may take several minutesInitial guess fitness: 0.5582710
Frame dimensions: 2521.6mm x 1079.3mm (aspect ratio: 2.34:1)
Fitness: 0.6001899 in 100
Fitness: 0.6041878 in 200
Fitness: 0.6069273 in 300
Fitness: 0.6097641 in 400
Fitness: 0.6207784 in 500
Fitness: 0.6215133 in 600
Fitness: 0.6215133 in 700
Fitness: 0.6215133 in 800
Fitness: 0.6215133 in 900
Fitness: 0.6215133 in 1000
Fitness: 0.6215133 in 1100
Fitness: 0.6215133 in 1200
Fitness: 0.6215133 in 1300
Fitness: 0.6215133 in 1400
Fitness: 0.6215133 in 1500
Find Anchor Values:
Fitness: 0.6215133
Maslow_tlX: 20.8
Maslow_tlY: 1082.9
Maslow_trX: 2546.6
Maslow_trY: 1076.5
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 2530.1
Maslow_brY: 0.0
Find Anchors
[MSG:INFO: Calibration already complete (waypoint 17 > pointCount 16), transitioning directly to READY_TO_CUT]
[MSG:INFO: Find Anchors state reset]
[MSG:INFO: Requesting state change from Find Anchors Computing to Ready To Cut]
[MSG:INFO: Synchronizing motor positions for READY_TO_CUT:]
[MSG:INFO: TL: 1220.843 TR: 1237.742 BL: 1226.501 BR: 1222.776]
