first build.
Finally set up my Maslow 4 no frame as of yet just getting through this part first.
*turn machine on
*log onto webpage
*hit ALARM
*go to setup
*hit retract all as directed in setup manual…
*dialog in code box says [MSG:INFO: Retracting all belts]
*nothing happens.
*check all connections
*try again
*Nothing
*be me see word test in setup.
*hit test
*Code box.
Serial Messages
[MSG:INFO: FluidNC v3.6.7 (Bringing-in-Maslow-changes-bit-by-bit-b659ebef-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:AFP-SV01]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.0.250]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Set to comply]
Index.html Version: 0.78
[MSG:INFO: Firmware Version: 0.78]
[MSG:INFO: Magnet detected on Top Left]
[MSG:WARN: Encoder read failure on Top Right]
[MSG:WARN: Encoder not found on Top Right]
[MSG:INFO: Magnet detected on Top Right]
[MSG:INFO: Magnet detected on Bottom Left]
[MSG:INFO: Magnet detected on Bottom Right]
[MSG:ERR: Encoder not found on Top Right]
- Problem found [MSG:ERR: Encoder not found on Top Right]
*Check forum find someone else talking about similar issue. Dam not same issue.
*Diagnosis time
*Issue - lights are on but weak barely lit. on both encoder board ethernet port and also on main board.
*Problem solving.
*Swapped ethernet cord from encoder front right to front left and the left to the right.
*front right encoder is now plugged into the front left motherboard
*front Left encoder is now plugged into the front right motherboard.
*front right encoder passes test disguised as front left
*Front left encoder light now dim and top right mother board is still dim, failed again
*Conclusion
*Encoders are fine
*some thing wrong with mother board.
*Tried update all files
*have turned on and off again.
hopefully these pictures help
