Can someone tell me what error 9 is?
I can’t get the error code list to come up
Thanks
Thanks
have look here
When you are jogging and you put in multiple Jogs the system is busy and puts a * 9: GCode cannot be executed in lock or alarm state. They can safely be ignored as the command is still processed when the system is ready. To avoid it you can change the Jog value (Click on the number in the centre and change how far you want to go in 1 step. For more information on error codes see Alarm and Error Codes | Wiki.js
Thanks!
Where were you seeing the broken link? I’ll fix that page
At the bottom of the setup guide page https://maslowcnc.github.io/Maslow_4/QuickStart.html
The link “error message documentation”
Thanks for catching that, I just updated the link to be correct. I’m sorry for the confusion there!
In case you don’t want to scroll down on that page the correct link is Error Messages — Maslow It looks like it didn’t get updated correctly when we moved to github pages for that page.
This is the grbl secret decoder ring for alarm codes, IDK if FluidNC added more. These are the error codes, errors and alarms are different. While they both use numbers they have totally different meanings
