What really is error 9? can anyone suggest what is going on here? The machine kind of works but keeps saying error 9 but usually it is ready to cut. It pulses a lot, so moves a bit side to side when z moves and also dips off track hard about 1mm at the start of a cut.
It’s a vertical setup.
here is the serial log:
Serial Messages
Index.html Version: v1.17
[MSG:INFO: FluidNC v1.17]
[MSG:WARN: Previous boot ended in panic - attempting to load config anyway]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:gpio.38 Disable:NO_PIN R:0.11]
[MSG:INFO: Connecting to STA SSID:Shackteau_2.4g]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.1.101]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://maslow.local/\]
[MSG:INFO: SSDP Started]
Grbl 1.17 [FluidNC v1.17 (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:INFO: Current z-axis position loaded as: 32.260]
[MSG:INFO: TL encoder angle difference too large (-1880 counts), treating belt positions as stale]
[MSG:INFO: Starting Maslow Version v1.17]
Release Tension
[MSG:INFO: Requesting state change from Unknown to Releasing Tension]
[MSG:INFO: Succeeded]
[MSG:INFO: Requesting state change from Releasing Tension to Unknown]
JogTo: $J=G91F300Z0.02 (mm)
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
JogTo: $J=G91F300Z3 (mm)
Retract All
[MSG:INFO: Bottom Left pulled tight with offset -1093.524]
[MSG:INFO: Top Left pulled tight with offset -1733.781]
[MSG:INFO: Bottom Right pulled tight with offset -1989.922]
[MSG:INFO: Top Right pulled tight with offset -2397.582]
JogTo: $J=G91F300Z-3 (mm)
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
Set Z-Stop
error:9
error:9
error:9
error:9
error:9
error:9
error:9
Retract All
[MSG:INFO: Requesting state change from Belts Retracted to Retracting Belts]
[MSG:INFO: Top Right pulled tight with offset -0.021]
[MSG:INFO: Bottom Right pulled tight with offset 0.011]
[MSG:INFO: Bottom Left pulled tight with offset -0.021]
[MSG:INFO: Top Left pulled tight with offset -0.043]
Extend All
[MSG:INFO: All belts extended to 1850.000mm]
Apply Tension
[MSG:INFO: Requesting state change from Belts Extended to Taking Slack]
[MSG:INFO: Center point deviation: TL: 0.000 TR: 0.000 BL: -0.751 BR: -1.270]
[MSG:INFO: Center point deviation within 12.000mm, your coordinate system is accurate]
[MSG:INFO: Requesting state change from Taking Slack to Ready To Cut]
JogTo: $J=G91F98.43X-10 (inch)
JogTo: $J=G91F98.43X-10Y-10 (inch)
JogTo: $J=G91F98.43X-1Y-1 (inch)
Home pos set for: Z
[G54:-495.417,-458.000,36.000,0.000,0.000]
JogTo: $J=G91F11.81Z-0.118 (inch)
JogTo: $J=G91F11.81Z0.118 (inch)
JogTo: $J=G91F11.81Z-0.02 (inch)
error:9
Home pos set for: Z
[G54:-495.417,-458.000,27.974,0.000,0.000]
JogTo: $J=G91F11.81Z0.02 (inch)
error:9
Home pos set for: X
Home pos set for: Y
[G54:-539.303,-458.000,27.974,0.000,0.000]
[G54:-539.303,-467.444,27.974,0.000,0.000]
[MSG:INFO: Program End]
[MSG: /sd/36 square test.nc file job succeeded]
JogTo: $J=G91F98.43X-0.0429Y-35.9549 (inch)
JogTo: $J=G91F98.43X-10Y10 (inch)
JogTo: $J=G91F98.43X10 (inch)
error:9
JogTo: $J=G91F98.43X0.0001Y-10.0001 (inch)
JogTo: $J=G91F98.43X-0.5Y-0.5 (inch)
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
Home pos set for: Z
[G54:-539.303,-467.444,29.117,0.000,0.000]
Release Tension
[MSG:INFO: Requesting state change from Ready To Cut to Releasing Tension]
[MSG:INFO: Requesting state change from Releasing Tension to Belts Extended]
Retract All
[MSG:INFO: Requesting state change from Belts Extended to Retracting Belts]
[MSG:INFO: Bottom Left pulled tight with offset 0.032]
[MSG:INFO: Top Left pulled tight with offset 0.021]
[MSG:INFO: Bottom Right pulled tight with offset -0.440]
[MSG:INFO: Top Right pulled tight with offset 0.118]
Retract All
[MSG:INFO: Top Right pulled tight with offset -0.129]
[MSG:INFO: Bottom Left pulled tight with offset -0.032]
[MSG:INFO: Bottom Right pulled tight with offset -0.011]
Extend All
Apply Tension
[MSG:INFO: Center point deviation: TL: 0.000 TR: 0.000 BL: -0.980 BR: 0.634]
JogTo: $J=G91F98.43Y-10 (inch)
JogTo: $J=G91F98.43Y-1 (inch)
Home pos set for: X
Home pos set for: Y
[G54:-260.435,-467.444,29.117,0.000,0.000]
[G54:-260.435,-490.291,29.117,0.000,0.000]
Home pos set for: Z
[G54:-260.435,-490.291,27.596,0.000,0.000]
error:66
JogTo: $J=G91F11.81Z0.2 (inch)
JogTo: $J=G91F98.43X-0.0431Y-35.9552 (inch)
Home pos set for: X
Home pos set for: Y
[G54:-514.437,-490.291,27.596,0.000,0.000]
[G54:-514.437,-490.300,27.596,0.000,0.000]
JogTo: $J=G91F98.43X0.5 (inch)
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
JogTo: $J=G91F98.43Y-0.5 (inch)
JogTo: $J=G91F98.43Y0.5 (inch)
JogTo: $J=G91F98.43X-0.5 (inch)
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
error:9
