I have a junk router
and there is a guide, of sorts
Let me check if I can find that ball here. I think I’ve seen it. I have a unused run down bathroom in a staff accommodation. It’s perhaps not very environmental to flush the powder done the drain?
A handheld gas torch, piece of scrap wood on a rope, the ring bracket, all in reach here. Plus the old GoPro that should give a nice slowmo. I think you set me up for something… Not this weekend but the next should be possible. Let me find that or a similar ball.
It would also be awesome to point an IR detector with a data logger on the bit for the test!
I’m not setting a router on fire
that damn rubbish china one perhaps, no. I still can mount that under a table.
I was more after a test if the top ring bracket deflects the powder in a way that the fire is not killed.
A handheld gas torch mounted in the middle pointing upwards was my idea.
Seeing the cloud, it will take out a fire despite the bracket. This guys are crazy:
He’s like that “Smarter Every Day” guy without the “smart” part. What a reckless ding dong.
I was thinking the exact same thing!
Yeah, extinguishing agent is meant to disrupt the oxygen cycle in a fire, getting it into your lungs is a BAD idea. And it will likely never come completely out of those clothes.
Looks like he’s trying out for the YouTube Darwin Award channel.
You got to die, or make yourself inable to reproduce any more to win a darwin award. Since he allready put at least 1 kid in the genepool, he is inelligable for the award
“Don’t explode to not be on fire” - errr …
Here we go. “Automatic fire extinquisher”. Just one fire extinquisher, but instead of a press-to-spray handle, it “works like a fire suppression system.” Dry powder, so OK for electronics etc. Should be perfect for garages/sheds/workshops, and only £28.
https://www.amazon.co.uk/FSS-UK-EXTINGUISHER-ELECTRICAL-SUPPRESSION/dp/B075ZZHGLJ
There are varieties with the business end on a hose with a mounting bracket, which would be best, but I can’t find a cheap one of those, though there’s no reason they should be more expensive. Probably worth hunting around more, on ebay or whatever, or just asking a local fire expert / pyromaniac
You can also buy the auto-sprinkler valve part quite cheaply, though you’d need a standard cylinder of CO2 with a turning on/off valve, rather than a COTS fire extinguisher to hook it up.
Those little “stove-top” aka “auto-off” things are cheap and might work fine too. But I find the standard fire extinquisher + standard sprinkler head approach much more convincing, since it’s essentially the same technology that corporations rely on.
https://www.amazon.com/WilliamsRDM-675-3D-Stovetop-Firestop-Rangehood/dp/B00FL6VU3Y
Just FYI:
The ball type, and the small canister type both work with a fuse, so I’d venture to say it would need to directly touch flame to “activate”. The automatic sprinkler type has a small plastic piece which melts at a specific temperature to activate.
If you’re thinking of mounting the ball or the puck to the sled (like I did), the puck type is very directional (in the direction of the wick.) I bet it would be effective 9 times out of 10, but if the router started a fire and then moved down before the flames hit the puck, I could imagine the charge missing enough of the fire that it might not actually do its job completely.
I can also imagine a scenario where the workpiece and/or sled catches on fire, and then moves so the sled is blocking the suppression system, and then moves to re-expose the fire to air.
Again, I’m not advocating leaving it unattended.
I would expect that the vast majority of the time when a fire is started, it’s
because the router is not moving. It does take a while for enough heat to build
up
Dry powder is NOT ok for electronics. The dry powder used in fire extinguishers is very corrosive and can destroy electronics quickly (or worse, cause numerous small problems due to areas bridged or separated by corrosion).
This is the reason that Halon was previously used in dedicated computer rooms of yore. There are halon replacements, but none of them are cheap that I know of. And it is pretty hard to get your hands on a halon extinguisher these days due to the production of halon being banned in the US as it is a major ozone depletor.
A CO2 extinguisher is probably your best bet for not damaging electronics
I posted this on a different thread and didn’t really get any response. GroundControl Crash on File Opening - #17 by Jayster
any computer or electrical stuff that gets the powder in it will need to be
replaced.
of.
And all of them require that you be working in an encosed space so that the gas
can displace enough oxygen to take care of the fire.
Not something for a garage hobbiest.
Agreed, but you aren’t going to be able to set one up to save your system
automatically.
at least not cheaply
I read the new motor shield’s AUX 5 & 6 ports allow control signals for things like a temperature based resistor (thermristor). Which makes me ask the next questions
#1 what thermistor would be good for this? There are a lot of inexpensive ones out there. or is there some kind of smoke sensor that would be better to connect to aux ports?
#2 how would one code the software so that upon a sudden temperature rise the router is automatically turned off via the AUX 1 terminal? or sound a 12v buzzer alarm.
Obviously you want to be in the room with maslow running, but it would be nice to have the machine turn off just in case you had to go to the bathroom or got distracted with phone call, etc.
Just a thought. My approach would be non-contact temperature sensing aimed at the bit. I would build a separate arduino nano system that triggers a relay to turn all power off. From my experience the scenarios that can cause fire hazard where due to the software freezing, buffer overflow and lost connection. So a system integrated in GC would not react any more.
A nano and perhaps https://www.sparkfun.com/products/9570 with a relay should not be to hard on the wallet.
