Firmware upload issue
recently purchased the m2. we are trying to update the firmware. we had to install the duo board on our IDE. then we chose the programming port. and uploaded 1.26 of the firmware. we received error message : avr/io .h. we have tried various combinations of ports and boards, double checked the file was unzipped.
forums told us that the firmware may come pre loaded. but we are having trouble getting any sketch uploaded. when we try and do a hard reset of the board we get error message below:
:Arduino: 1.8.13 (Mac OS X), Board: “Arduino Due (Programming Port)”
In file included from sketch/Maslow.h:40:0,
from sketch/Axis.cpp:19:
RingBuffer.h:21:11: error: redefinition of ‘class RingBuffer’
class RingBuffer{
In file included from /Users/mudafuckinbizznasty/Library/Arduino15/packages/arduino/hardware/sam/1.6.12/cores/arduino/UARTClass.h:23:0,
from /Users/mudafuckinbizznasty/Library/Arduino15/packages/arduino/hardware/sam/1.6.12/variants/arduino_due_x/variant.h:38,
from /Users/mudafuckinbizznasty/Library/Arduino15/packages/arduino/hardware/sam/1.6.12/cores/arduino/Arduino.h:201,
from sketch/Maslow.h:26,
RingBuffer.h:30:7: error: previous definition of ‘class RingBuffer’
class RingBuffer
from sketch/GCode.cpp:21:
class RingBuffer{
class RingBuffer
sketch/GCode.cpp: In function ‘void initGCode()’:
GCode.cpp:32:21: error: ‘class RingBuffer’ has no member named ‘empty’
incSerialBuffer.empty();
sketch/GCode.cpp: In function ‘void readSerialCommands()’:
GCode.cpp:64:54: error: ‘class RingBuffer’ has no member named ‘write’
int bufferOverflow = incSerialBuffer.write©; //gets one byte from serial buffer, writes it to the internal ring buffer
from sketch/Motion.cpp:17:
class RingBuffer{
etc…
Please Help. what are we missing? anything would be helpful!
Thank you.
@makermade do you guys have any thoughts? This is beyond my understanding of that machine.
We have now successfully reset the board. in an effort to start from scratch. when trying to upload the firmware we now get error message : redefinition of ‘class Ringbuffer’
thanks again for any help. @MakerMadeCNC
Version 1.26 is for the mega. it won’t work. You have a due. Try this version.
This is the correct link, thanks for sharing. @Fiber.studios.co if you still have trouble, you can send a note to support@makermade.com requesting additional instructions for firmware update
