First Cut Today!
I assembled my router back in March when it first arrived, I was among the first to have a belt eaten during calibration. I kept attempting to calibrate through the spring, got disillusioned and busy in the summer. I just tried calibrating with v.85 (last attempt was v.72). Calibrated very nicely! So I just cut out a quick silhouette of a dog out of a plywood scrap.
I have decided we need a feature that my embroidery sewing machine has, a button to jog to the outer corners of the box enclosing the complete design. I cut it again on another piece of scrap ply and ran right off the edge.
Awesome. Could you share the bit you used, your settings and the thickness of your plywood sheet (feedrate, router speed, etc.) ?
Half inch plywood of unknown provenance, cheap B/C stuff. 1/4 in compression bit, rpm unknown but DeWalt 611 set to 5. Movement was slow compared to what some folks have. Been experimenting with only 500mm/min. Cut depth .2 inches.
I’m pretty sure I could be more aggressive… But slowly at first for me.
Glad to hear the calibration was better! We put a lot of work into improving it!
The feature with the box is a great idea. I’ve been essentially doing it manually but just jogging the machine. But adding a button would be much faster.
