Greetings all!
First off, I’m Loving cutting with my M4. It’s awesome to see it go and my students love it. I’m on my second student furniture job when things went very sideways. I was cutting on the section that is in the upper left of the picture when the sled started doing the nose rocking thing.
This spot is a little over 3 feet from the left side and 3 feet down from the top, so I would hope we are not running into the problem of being too close to a side.
It then disconnected from Wifi. I stopped the job, retract, reset z stop, reset z home, extend, tighten, send back to the home, and started a new gcode that eliminated already cut toolpaths.
I had to up the retraction force to 1700 or 1800 from the 1000 that it was at to get the upper left belt to retract this time. I noticed the upper left servo motor kind of wondering about. like the end was moving in a circle relative to the paddle while the others didn’t move. Also I notice a terrible sound and a strange vibration coming through the belt coming from that paddle when I was extending the belts. Has anyone seen this? I’m guessing this has to do with the servo being loose.
Maslow-serial 2-26 @ 152 PM.log (4.0 KB)
Maslow-serial 2-26@ 237 PM.log (4.0 KB)
I looked at another post from dlang and he advised that the inner spool was loose and that was causing the problem. I will be looking into this tonight.
Then when I was getting it set up a 3rd time, I couldn’t control the Z axis. I kept getting Error 9. On another form I saw that error indicated gcode was still running. There was no gcode loaded, the green box said jog, and the state was unknown. It had been power cycled since trying to run it. So I took it down, and I noticed a strange sound. the Z axis motors were moving ever so slightly, but way after I had commanded them to. Also they were both hot.
Maslow-serial 2-26@ 305PM.log (4.0 KB)
At this point I am going to take the thing home and dismantle it. Maybe when I get home the steppers will have cooled off and it will be controllable for me again. I will be moving to the turtle clamp base since my hardware finally came in for it, as well as upgrading to 1.18. However if any of this rings a bell and anyone has any pointers for me on how to fix them, I would love to hear your expertise.
Thank you all for your help,
Update: I realized I needed to travel and wanted to take the bit out. So I gave it another shot to move the Z axis. It moved and had no issues.
Maslow-serial2-26 @354PM.log (3.7 KB)
Thank you all!
