I am repeatedly having an issue with maslow…. maybe hardware related? the belts all extend and retract as normal, seems very repeatable.
I made a cut a few weeks ago, everything went fine. I was even able to start this week and run part of my program without issue, but maslow got stuck with a location error mid-way through and i haven’t been able to get anywhere since. I was running v1.07 but i updated to 1.11 this week, hoping it would help, but no dice. Log file is below. Basically all I did was fix the z height after the ‘apply tension’ changed it for some reason and hit go. Any ideas where to start looking for a fix?
Serial Messages
Index.html Version: 1.11
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Aggienetwork]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 10.79.1.55]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://maslow.local/\\]
[MSG:INFO: SSDP Started]
[MSG:INFO: Caution: Unlocked]
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Top Right pulled tight with offset -0.011]
[MSG:INFO: Bottom Right pulled tight with offset -0.064]
[MSG:INFO: Top Left pulled tight with offset -0.183]
[MSG:INFO: Bottom Left pulled tight with offset -0.140]
Extend All
[MSG:INFO: Center coordinates updated in MaslowKinematics: X=1407.391 Y=1209.731]
[MSG:INFO: All belts extended to 1750.000mm]
Apply Tension
[MSG:INFO: Requesting state change from Belts Extended to Taking Slack]
[MSG:INFO: Center point deviation: TL: -0.000 TR: 0.000 BL: 5.345 BR: 6.654]
[MSG:INFO: Center point deviation within 12.000mm, your coordinate system is accurate]
[MSG:INFO: Current machine position loaded as X: -28.804 Y: -18.970]
[MSG:INFO: Before update - mpos: X=nan Y=nan Z=1.300]
[MSG:INFO: Setting motor positions directly from measurements:]
[MSG:INFO: TL belt: 1717.172 TR belt: 1742.077]
[MSG:INFO: BL belt: 1673.941 BR belt: 1717.129]
[MSG:INFO: After update - mpos: X=-28.801 Y=-18.971 Z=0.000]
[MSG:INFO: Requesting state change from Taking Slack to Ready To Cut]
JogTo: '$J=G91F300Z-5
Home pos set for: Z
[G54:9.582,-510.472,-5.000,0.000,0.000]
JogTo: '$J=G91F300Z5
[MSG:INFO: Tool No: 1]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.003mm Counter: 1]
[MSG:WARN: Previous error was 15.003mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.006mm Counter: 1]
[MSG:WARN: Previous error was 15.006mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.056mm Counter: 2]
[MSG:WARN: Previous error was 15.056mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.036mm Counter: 1]
[MSG:WARN: Previous error was 15.036mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.098mm Counter: 2]
[MSG:WARN: Previous error was 15.098mm]
I had similar errors at one stage when it was running on a vertical frame. I have since gone to horizontal and I pulled the Maslow apart and sanded the belt axis and greased them with a mixture of petroleum grease and graphite. I have not seen this problem since. I think it was the excess friction on the belts causing the problem.
Ian, isn’t petroleum bad to use on certain plastics? I thought I read that it can soften plastics. Is it safe to use on whatever plastic the spools are made from?
While it works in the short term, it may degrade plastic over time. So do your research and decide for yourself. Some of the synthetic lubricants may have less long term downside effects.
This sounds a bit like one or more of the belts is binding. Try setting the retraction force really low 200 and doing multiple retract extends until all of the belts are out as far as they will go, then reset the retraction force and pull all the belts back in, maintaining a little resistance pressure to ensure they pack down properly. When you have the belts full extended it wouldn’t hurt to blow them out with an air pressure hose if you have one to get rid of any sawdust etc
I recalibrated on the past 2 days, and I forgot to set the frame size to something reasonable first, so I pulled out like 2x as much belt as I needed during that process, so I think we’re good there.
@bar video linked. honestly it moves like normal, acts like it’s about to cut, and then i get the position error. VIDEO
not sure if you can see it in the video, but after the error, the lights on the maslow turns red and flashes blue. then it disconnects from my computer and won’t reconnect until a power reset.
And here’s the latest log file, basically same as the first. it is consistently that same BL arm, but it doesn’t act strangely, i don’t have any issue with retract, and the belt seems to go to the same length every time…
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: [MSG:INFO: Channel auto report interval set to 50 ms]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: [MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:gpio.38 Disable:NO_PIN R:0.110]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://maslow.local/\]
Release Tension
[MSG:INFO: Requesting state change from Unknown to Releasing Tension]
[MSG:INFO: Requesting state change from Releasing Tension to Unknown]
Retract All
[MSG:INFO: Bottom Right pulled tight with offset -1430.787]
[MSG:INFO: Bottom Left pulled tight with offset -1467.612]
[MSG:INFO: Top Left pulled tight with offset -2092.141]
[MSG:INFO: Top Right pulled tight with offset -2045.374]
Retract All
[MSG:INFO: Requesting state change from Belts Retracted to Retracting Belts]
[MSG:INFO: Bottom Right pulled tight with offset -0.021]
[MSG:INFO: Top Right pulled tight with offset -0.064]
[MSG:INFO: Bottom Left pulled tight with offset -0.097]
Extend All
Apply Tension
[MSG:INFO: Center point deviation: TL: 0.000 TR: 0.000 BL: 3.024 BR: 5.161]
[MSG:INFO: Current machine position loaded as X: -11.403 Y: -4.346]
[MSG:INFO: Before update - mpos: X=nan Y=nan Z=0.000]
[MSG:INFO: TL belt: 1720.530 TR belt: 1719.360]
[MSG:INFO: BL belt: 1694.345 BR belt: 1711.750]
[MSG:INFO: After update - mpos: X=-11.408 Y=-4.345 Z=0.000]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.021mm Counter: 1]
[MSG:WARN: Previous error was 15.021mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.048mm Counter: 1]
[MSG:WARN: Previous error was 15.048mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.085mm Counter: 2]
[MSG:WARN: Previous error was 15.085mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.004mm Counter: 1]
[MSG:WARN: Previous error was 15.004mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.029mm Counter: 2]
[MSG:WARN: Previous error was 15.029mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.079mm Counter: 3]
[MSG:WARN: Previous error was 15.079mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.129mm Counter: 4]
[MSG:WARN: Previous error was 15.129mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.034mm Counter: 1]
[MSG:WARN: Previous error was 15.034mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.084mm Counter: 2]
[MSG:WARN: Previous error was 15.084mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.134mm Counter: 3]
[MSG:WARN: Previous error was 15.134mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.184mm Counter: 4]
[MSG:WARN: Previous error was 15.184mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.025mm Counter: 5]
[MSG:WARN: Previous error was 15.025mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 15.075mm Counter: 6]
[MSG:WARN: Previous error was 15.075mm]
[MSG:INFO: Reset during file job at line: 28]
[MSG:ERR: Position error > 15mm while running. E-Stop triggered.]
The log below, I jogged the machine around for a bit to see if i could cause the error from that, no issues, but the instant i hit ‘start’ on a program, the error shows up and the machine stops:
Serial Messages
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
Retract All
[MSG:INFO: Bottom Right pulled tight with offset -0.011]
[MSG:INFO: Top Left pulled tight with offset -0.140]
[MSG:INFO: Top Right pulled tight with offset -0.021]
[MSG:INFO: Bottom Left pulled tight with offset -0.075]
Extend All
Apply Tension
[MSG:INFO: Center point deviation: TL: 0.000 TR: 0.000 BL: 4.427 BR: 5.836]
[MSG:INFO: Current machine position loaded as X: -28.423 Y: -17.503]
[MSG:INFO: TL belt: 1716.480 TR belt: 1740.835]
[MSG:INFO: BL belt: 1674.271 BR belt: 1716.958]
[MSG:INFO: After update - mpos: X=-28.428 Y=-17.501 Z=0.000]
JogTo: '$J=G91F2500X-400Y-400
JogTo: '$J=G91F2500Y400
JogTo: '$J=G91F2500X400
JogTo: '$J=G91F2500Y-200
JogTo: '$J=G91F2500X-200Y200
JogTo: '$J=G91F2500X38.01Y-492.97
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 18.918mm Counter: 1]
[MSG:WARN: Previous error was 18.918mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 23.173mm Counter: 1]
[MSG:WARN: Previous error was 23.173mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 18.918mm Counter: 2]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is 23.173mm Counter: 2]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 18.918mm Counter: 3]
Hmmm yeah that is super strange. We had a bug that was similar but it was causing issues when moving to where it was going to start cutting, and this seems to be an issue once it has already gotten to where it is going to start cutting.
Can you post the gcode? I’ll try running it and see if the same thing happens for me.
Can you give this gcode a try and see if you have the same issue with this test file? No need to actually be cutting
So i had to hit ‘stop’ before your program got to the end of the jog, since i didn’t reset my home before i hit ‘go’ and it’s a bigger “Hello World” than I thought, lol. Regardless, the two trailing belts started spooling out pretty significantly to where I would have hit ‘stop’ anyway. VIDEO
(please pardon the messy garage, it’s a disaster, but it’s been too hot here to clean it out like it needs)
Look like I got it working. I was having issues with earlier firmware, so I upgraded to 1.10 and figured I’d do a calibration with the new method and basically the 5x5 grid wasn’t good enough. I got values that were up to 100mm different from when I previously ran calibration on a 7x7 grid.
So basically I plugged those values in, upgraded to 1.11.2 and now everything seems to be working again.
