I surprisingly received a MakerMade Maslow kit for Christmas complete with the pre-cut sled, and have begun the process of obtaining the router & other hardware and planning my frame design. I’m planning to run WebControl on a Raspberry PI 4b, and the ‘standard’ Ridgid 2202 router.
I’m fairly sure that my kit came with the ‘standard’ 11-foot lengths of chain, and I’m looking for ways to optimize that while still allowing as wide a top beam as possible. From what I’ve seen in the forums, proper chain tension is a busy topic, but I stumbled across a frame design (that I can no longer find again) that used weighted sleds riding a parallel surface beside the cutting area, and was thinking of doing something along those lines.
Does that sort of tension setup free up enough chain length to be able to go to a full 12’ beam, since it wouldn’t have to run into the center along a pulley setup, or should I start narrower and eventually upgrade the width when I can get my hands on some longer chains?
Overall, I’m thinking something similar to the 80/60 build, with a sled-support border of 12" all the way around, and then a 9" vertical ‘slide’ zone. I’m thinking that should keep the weights clear of the sled.
Are there pitfalls to that design that I should be aware of?
How much weight should I expect to need on each side, I’m seeing some people say 5 lbs is too much, and others saying that’ll be fine?
