Ground control keeps crashing 45 secs after launching. Help please.
Send me a private message with your email and I will send you a version which pauses before closing so we can read the error message.
Checking out Web Control might also be a good option to explore.
Here you go
I got the ground control going not the machine is stuck cutting in one area over and over. for example im trying to cut out the letter P so the machine cuts the center piece then when is time to cut the rest of the P it goes back to cut the same part it just finished cutting. Any idea how to fix this?
That is usually an issue with the gcode file. Can you post a copy of the gcode?
I worked him through it on the other post and then through email (he had reached his post limit for a new user). Was the DoC setting that needed to be updated…
