When starting Ground Control and after selecting witch port (COM12), Ground Control seems to connect and then abnormally quits. Any ideas? Running Windows 7
There’s an issue with v1.19 of GroundControl that can cause this. When the new groundcontrol.ini file is created, the section for propweightz in [Computed Settings] is not created.
The quick-and-dirty workaround is to add this line to groundcontrol.ini at the end of the [Computed Settings] section.
propweightz = 1
The groundcontrol.ini file will be in your home folder.
Another workaround would be to download and use the v1.18 release which didn’t have that problem.
Thanks. I moved the old .ini file over and it works now.
