From version 1.17, I cannot get ground control to open. It closes after opening, before the GUI loads.
https://www.insigniaproducts.com/pdp/NS-P10W8100/5855905
This is my tablet I’m using. I’m sorrry I cannot find where to log file is. The only one in ground control is a 0 file size.
I have been using 1.17 with the latest firmware. I also loaded both master files and it won’t load. What should I try next?
bar
October 2, 2018, 11:06pm
2
Blsteinhauer88:
From version 1.17
Do you mean every version after 1.17? Is this while running from the source version by any chance?
Yes, I read that it was a problem. Then I saw it was fixed. But each version for me won’t load after 1.17
Yes source version
bar
October 2, 2018, 11:11pm
4
Got it! The issue is that after 1.17 the source version requires a new module to run called pillow running the command pip install pillow should fix things
Thanks I will try that when I get home!
Ok pip install pillow is not working?
