Hey all,
I tried to calibrate my maslow a couple of times but when finished the same error always occurs:
When GC is connecting to the controller it is shutting down.
When the maslow is not connected it is working fine. When I erase the Groundcontrol.ini file in my user file it is editing a new ini file and GC is working for new calibration process and some test cuttings (maybe 3). Then it starts crashing all the time.
I am Using GC 1.26 and also the firmware with 1.26
OS is windows (i tried multiple computers)
It is so frustrating being just about to start to get some jobs done with the Maslow, and then, after some test cutting it is not working anymore.
Here is my log file:
Connected on port COM3
PCB v1.2 Detected
Grbl v1.00
ready
ok
Sent: $$
[Forward Calculating Position]
<Idle,MPos:0.00,0.00,4.99,WPos:0.000,0.000,0.000>
[PE:0.00,0.00,123]
position loaded at:
-0.00
-70.24
$0=2438.40 (machine width, mm)
$1=1219.20007324 (machine height, mm)
$2=2978.40014648 (motor distance, mm)
$3=463.00000000 (motor height, mm)
$4=310.00000000 (sled width, mm)
$5=139.00000000 (sled height, mm)
$6=79.00000000 (sled cg, mm)
$7=1 (Kinematics Type 1=Quadrilateral, 2=Triangular)
$8=100.00000000 (rotation radius, mm)
$9=2000 (axis idle before detach, ms)
$10=3360 (full length of chain, mm)
$11=1650 (calibration chain length, mm)
$12=8113.72998046 (main steps per revolution)
$13=63.50000000 (distance / rotation, mm)
$15=800 (max feed, mm/min)
$16=0 (Auto Z Axis, 1 = Yes)
$17=0 (auto spindle enable 1=servo, 2=relay_h, 3=relay_l)
$18=12.60000038 (max z axis RPM)
$19=3.17000031 (z axis distance / rotation)
$20=7560.00000000 (z axis steps per revolution)
$21=1300.00000000 (main Kp Pos)
And my groundcontrol.ini:
[Computed Settings]
distperrot = 63.5
kpposmain = 1300
kiposmain = 0
kdposmain = 34
propweightmain = 1
kpposz = 1300
kiposz = 0
kdposz = 34
propweightz = 1
kpvmain = 5
kivmain = 0
kdvmain = 0.28
kpvz = 5
kivz = 0
kdvz = 0.28
chainoversprocketcomputed = 1
fpwmcomputed = 3
kinematicstypecomputed = 2
[Maslow Settings]
bedheight = 1200
openfile =
motoroffsety = 412.7
sledwidth = 310
zaxissafeheight = 5
bufferon = 0
bedwidth = 2450
comport = COM3
macro1_title = Macro 1
sledheight = 140
macro2 =
macro1 =
zaxis = 1
sledcg = 79
macro2_title = Macro 2
colorscheme = Light
zdistperrot = 1,5
motorspacingx = 3003.5
[Advanced Settings]
rotationradius = 141.1
chainextendlength = 1650
kiv = 0
gearteeth = 10
spindleautomate = None
kdvz = 0.28
chainsagcorrection = 19.943061
chainpitch = 6.35
chainlength = 3360
propweightz = 1
zencodersteps = 7560.0
maxfeedrate = 800
enablepospidvalues = 0
rightchaintolerance = 0
enablevpidvalues = 0
maxtouchprobeplungedistance = 0.0
kpvz = 5
kdposz = 34
chainoversprocket = Top
kpposz = 1300
fpwm = 490Hz
kdpos = 34
encodersteps = 8113.73
truncate = 0
homex = 0.0
homey = 0.0
kinematicstype = Triangular
kipos = 0
kdv = 0.28
kiposz = 0
digits = 4
kppos = 1300
kpv = 5
propweight = 1
positionerrorlimit = 2.0
kivz = 0
leftchaintolerance = 0
[Ground Control Settings]
zoomout = pagedown
centercanvasonresize = 0
viewscale = .45
zoomin = pageup
validextensions = .nc, .ngc, .text, .gcode
[Background Settings]
backgroundfile =
manualreg = []
Sry for the long post. I hope you can help me.
I have already gone through some posts here in the forum.
thanks in advance.
