Hi and thanks for reading my post, I haven’t be able to make my maslow to work, my problem is at the calibration stage, Let me give you the technical info.
Your Operating System with version :Windows 10 home
Firmware and GroundControl version: 1.25
Temporary frame : sled
Z- axel:manual Z adjustment
*firmware :1.26
And the problem is that when I run the calibration wizard at the part when I have to stretch the chain I have notice that certain buttons doesn’t work And i think it may be the ground control version since it shows me a message saying that the firmware version is 1,26 and the grond control is 1.25 but I couldnt find the portable version of the ground control 1.26.
The chains moves, but for example, I was runing the automatic calibrating proces and was on the step where it says that the distance between motors will be meassured using the chain, so I align the tooth vertically and from there I use the “extend button” to make the chain reach the right motor and once it reaches I place the 3th chains ling to the vertocal tooth of the right motor, but the chain is not thigh-ted and if i ise the retract button it doesn’t do nothing… and If I us ethe button “Pull the chain thigh and measure it do nothing”
I have tried to do the process several times and is the same, I though it was because the difference of version between GC and the firmware.
I don’t think are the motors because if U use the buttons the allows me move the gear teeth they move without any problem.
Hopefully you guys can help me.
Thanks a lot.
