I switched my control computer from KDE/plasma to xmonad and now GroundControl is stuck at a fixed size no matter how big the window is. In the attached picture the UI should fill half the screen. If I move the terminal away for fullscreen all the GroundControl buttons stay exactly where they are now and the black space around it gets bigger.
I’ve got some Python experience but I’ve never touched any X libraries. I poked around but couldn’t find anything obvious. I suspect the root cause is deeper in Kivy but I have no idea where to start. While searching the forums for similar problems I also discovered WebControl exists and will be trying that in case we can’t find a solution for GroundControl.
averdow@maslow ~/GroundControl $ uname -a
Linux maslow 5.7.6-arch1-1 #1 SMP PREEMPT Thu, 25 Jun 2020 00:14:47 +0000 x86_64 GNU/Linux
averdow@maslow ~/GroundControl $ xmonad --version
xmonad 0.15
averdow@maslow ~/GroundControl $ git log | head
commit e48bf5b2f120c5017444e37436b00fc3a03c09a6
Merge: 974e7cf a93d6ea
Author: MaslowCommunityGardenRobot <info@maslowcnc.com>
Date: Fri Nov 15 13:55:48 2019 -0800
Merge pull request #810 from MaslowCNC/Update-distance-scale-for-safe-height
Change scale factor for safe z-height
commit a93d6eaf26f1171a7987afbff7c188adabef62c3
