I tried cutting out a job with my Maslow 4 that has edges close to the far edge of the work area (x is about 3cm).
My machine plunged into my floor and wrecked my mill.
After some debug (no mill in the machine and a marker at stock height taped above a z motor) I found the problem, although I don’t know how this one might be fixed.
The machine puts so much tension on the leading belts that the z motor stalls as the machine trys to reduce z depth whilst simultaniously increasing y (basically the y movement prys the sled onto its highest y edge so it would be doing a tiny endo if it were a BMX).
@bar, @dlang this is a tricky one. I think the top right arm having the steepest angle to the floor and the bottom left belt having the shalowest is contributing to this, so I will try to reduce angle of the top left with some stock height shims on the high anchor and re-calibrate. Otherwise, stumped. Video attached. You can hear the z axis groaning and failing. If my job depths were respected, the little stick would not bottom out. The warping in the tape is caused by an artificial offset being added progressively to z due to this problem. After this failure I saw about a 1/8" to 1/4" difference of exposed lead screw, but forgot to take a photo of that.
