I have not tested it yet.
If anyone has experience with this please share it with the group.
I noticed that DXF2GCODE is now in the Debian package repository’s for SID/Buster. I downloaded it and installed it on my RPi 3 running Jessie and it works. It also pulls in and uses PStoEDIT which does PDF to DXF on the backend,
Has anyone got any hints for this software? It might be ideal for my application, and for Maslow users at large.
I have downloaded the software and it runs.
I have created my DXF file in QCAD.
I have loaded the DXF in DXF2GCODE, and I see the shape I want in the application window.
(Insert what to do next here)
Then load the G-Code onto Maslow
I loaded the G-Code for my first attempt into ncviewer, and I saw only a long line, which makes me think I got the X-Y plane wrong, however I haven’t really found anything to tell me what to do, so I was hoping someone else has some information to help me.
It’s quite exciting as I really like QCAD and I haven’t really got to grips with FreeCAD. Also, I found out how to export 2D DXF files from OpenSCAD, which I also like a lot for 3D printing work, but I could use to quickly whip up a shape for Maslow.
Incidentally I also just played with ‘ezdxf’, which is a Python program for making DXFs. This means I can programmatically make a template for the thing I want, load it into QCAD and add the details, then (hopefully) use DXF2GCODE to get it onto the Maslow. For me that would be a very quick and simple workflow.
Yes, indeed. It’s the world’s least helpful wiki.
It does look very incomplete, indeed.
I did play with dxf2gcode couple of years back, but remember nothing.
I’ll try to play with it over the weekend.
Thanks. I think I’m only missing one thing. As I said, I have the DXF and it looks right when I open it in the DXF2GCODE program. I also found somewhere to specify my 1/4" (6.35mm) cutter, and a way to specify on each line in my drawing whether I am cutting to the left or right (for outlines and cutouts).
I’d really like to get it going as it means the workflow from idea to object would be really smooth.
Ok. I think I’m onto it. I will document the steps here, but part of the reason for my confusion is that I cannot preview the output on ncviewer, but I can preview it on https://nraynaud.github.io/webgcode/
I need to look at the G-Code itself, but it looks promising. I might also just run it on the Maslow and see if it works.
The goal is this simple workflow:
Your favourite CAD program -> DXF -> DXF2GCODE -> G-Code file -> Maslow
I’ve started a tutorial here. Anyone who can help would be welcome.
