Hi everybody,
Off by only 1/16 of an inch diagonally…
What a relief getting this working instead of packing it up!
Thank you Tim
Hi everybody,
Thank you Tim
Awesome! For what its worth, everyone here has been in the same place as you at least once. Glad that you were able to get things going.
Glad you got it going!
Looking at your setup. You may want to shorten those bungees holding the chains so they don’t sag and catch when you are in the upper corners.
Please, am having a similar issue of not being able to load Makerverse after loosing a previous network configuration/setting on my MacOS.
Have a fresh PC setup and no luck there with Makerverse login. Receive “Network Error” consistently.
You need to enable guest mode like this post:
Thanks!
That definitely, “moved the chains” for the MAC. Lost my 3Dprinter “machine” though?
The PC and accessing makerverse is solved. Although the PC, not seeing the M2 as a machine. Guessing that the makermade firmware needs installed/upated?
did you try to copy your .makerverse file from the mac to the pc?
No, PC was a fresh install.
Is that a recommended suggestion?
If you want the same machines it will save you from reconfiguring. The calibration is stored on the Arduino, but the other settings are in that file. It may give you issue for the port name until you change it, but should work.
