With the new calibration routine that measures the distance of a cut below the top edge of the worksurface, how important is the measurement during Step 5 that measures the height of the motors above the worksurface? Is it critical now? I ask because my chain does not “hang” straight down from the sprocket because I pushed the slack idler out as far as I could so as to get the most wrap around the sprocket. When the chain hangs off the sprocket, it bumps into the idler (never does under normal cutting). I didn’t worry about it before because it just sets the center of the worksurface. Does the new cal routine use this value in anyway? I’m sitting here on Step 5…
I’ve been through the v1.03 calibration routine a half dozen times (triangular linkage) and skipped that step every time. My experience is that Step5 isn’t needed for a triangular linkage calibration setup.
Thanks… Pretty quick response
the new triangular calibration figures out that height, so that step needs to be
removed/ignored
what was that discussion about needing a different communication tool to provide
real-time responses?
I timed it… 5 minutes
